Community Member
top talkers
I have terminated the point to point link on 3550 switch.
Is there any way to obsreve top talkers on switch
on router i have excuted the command
ip flow-top-talkers
top 200
Everyone's tags (2)
Hall of Fame Super Gold
top talkers
sh ip flow top
top talkers
hey leo,
i've tried this on one our 1941 but i'm getting an error. do you know what i'm missing?
1941(config)#ip flow-top-talkers
1941(config-flow-top-talkers)#sort-by bytes
1941(config-flow-top-talkers)#cache-timeout 60000
1941(config-flow-top-talkers)#exit
1941(config)#int g0/1
1941(config-if)#ip flow ingress
1941(config-if)#ip route-cache
1941(config-if)#do show ip flow top
% Top talkers not configured
top talkers
Hi John,
Did you configure "top 200" command on 1941?
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards, Ivan Shirshin **Please grade this post if you find it useful.
top talkers
whoops! i forgot that line. thanks! +5
i was following leo's thread and missed it.
https://supportforums.cisco.com/message/3640049
Community Member
top talkers
Hi Ivan,
Is it supported on 3500 or 3750 ?
top talkers
Hi Prashant,
3750 and 3560 switches do not support netflow, but there is a service module which can be inserted into 3750X and this supports Flexible Netflow (FNF). The commands are available but  will not work unless the module is installed.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/data_sheet_c78-584733.html
The netflow support matrix can be seen in table 1 here:
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6555/ps6601/prod_white_paper0900aecd80406232.html
Kind Regards,
Ivan
top talkers
Glad it works, John :-) Thanks for rating the post.
3127
