Total Devices in the RACK power consumption
Dear All,
I have installaed and powered on the follwoing devices in the single 42u cabinet
Cisco 4507R with dual sup V and 24 x 10/1000 single switch module
cisco 4500 1400W power supply x 2
4x NAC 3310
1 x CSMARS
4 X 2960 (24 PORTS)
2 X IPS 4240
2 X ASA 5520
2 X 2811 ROUTERS
Please tell me how much total power i would all together consume?
They are facing frequent power triping in this cabinet.
swami
Re: Total Devices in the RACK power consumption
HI Swami, [Pls Rate if HELPS]
I don't thinkso this can be answered here.
Neverthless, this can be validated with your Maintanence Team for exact requirement.
In addition, please read the Manual of each equipment where you can find Recommended Power Requirement for easy Run.
Pls Rate if HELPS
Best Regards,
Guru Prasad R
Are you running all of the equipment on 208volts? This will help me give you a better estimate.
snm
133
