05-08-2012 08:18 PM - edited 03-07-2019 06:35 AM
How many of the VWIC2-2MFT-T1/E1 can be used in the 2801, all for data?
I know here it mentions how many slots support what, but its a bit confusing, and I remember having trouble bringing up the card in slot 2 and had to move card to third slot, I'm running 12.4(25b), and need to add 2 more T1 interface for a total of 6, all for data.
• 4 slots; 2 slots support HWIC, WIC, VIC, or VWIC type modules
• 1 slot supports WIC, VIC, or VWIC type modules
• 1 slot supports VIC or VWIC type modules
05-08-2012 08:22 PM
Kindly refer to the data sheet below:
Cisco 2nd Generation 1 and 2 Port T1E1 Multiflex Trunk Voice WAN Interface Cards
05-09-2012 07:35 AM
That document does not specify if all slots in the 2801 support it, only that the card is supported in general. Can anyone confirm if it will run in slots 2 and 4?
05-10-2012 06:49 PM
Since I'm using these ports for data, will a HWIC-4T1/E1 run on a 2801?
05-11-2012 06:42 AM
Usually the VWIC are supported on slot 2 or 3. So the VWIC2-2MFT-T1/E1 should work in slot 2. Could you post 'show diag' when you had the module in slot 2
And to answer your question - the HWIC-4T1/E1 is 'not' supported on 2801 router.
PS: Rate all the posts if it answers your question.
