Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
traceroute and GRE
how traceroute display hops when there is a GRE tunnel in the middle of the path. for Example hop 1,2,3,4-------8 GRE,9,10,11,12,13,14,15.
VIP Super Bronze
Re: traceroute and GRE
The GRE tunnel is one hop no matter how many devices it goes over.
Reza
if we create GRE tunnel for hop1 to hop5 and then normal IP path ,traceroute first display 8 th hop IP address as 5th hop.
PC------------>1-------------------------GRE--------------------5,6,7,8,9,10
if we traceroute from PC,
1. * * * (say node 1 node allowed to display its IP)
2. * * *
3. * * *
4. * * *
5. IP address of 8 th hop
6. IP address of 8 th hop
7. IP address of 8 th hop
this mean TTL reduce process starts at the end of GRE tunnel and it will go to TTL=0 at 8th hop. so it will not display hop 5,6,7 IP addresses. can this happen or IP payload TTL value should reduce according to number of hops passed through GRE at GRE end point.
488
