traceroute through firewalls
Hi all, can anyone tell me why when I traceroute through my firewall, I cannot see the ip, what do i need to enable on my asa so you can see it as a hop ?
Silver
Re: traceroute through firewalls
Hi Carl,
By default firewall interface does not respond to ping,traceroute(icmp pkts) being security device . However, you can configure its interfaces to respond to icmp .
enable following commands:
icmp permit any outside
icmp permit any inside
Saju
Pls rate helpful posts
is that part of an access list or seperate commands? and why do you need to do it on the inside , does the inside not respond to ping by default, i can normally ping the inside by default
Silver
no they are just commands . Just input those commands when you are in config mode.
check your config , maybe its already enabled for inside interface.
506
