02-16-2014 10:33 PM - edited 03-07-2019 06:14 PM
HI all
please i want to run Netflow on my CIsco switch 3750x-TE, but it seem doesn't support on it , could u please guide me to use another feature on cisco to work as netflow for traffic analysing ?
02-16-2014 10:35 PM
Hi Rawa,
You can use flexible netflow. Here is the link to the guide:
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
02-17-2014 12:41 AM
Dear Ivan
please i can't run the configuration of Flexible Netflow on my switch , please help
02-17-2014 12:47 AM
Hi Rawa,
Are you not able to configure it or encounter some issue during configuration?
Note that Flexible NetFlow is supported only on the Catalyst 3750-X and 3560-X switch running the IP base or IP services feature set and equipped with the network services module. It is not supported on switches running the NPE or the LAN base image.
Kind Regards,
Ivan Shirshin
02-17-2014 11:53 AM
Thanks Ivan
find my switch Model in below table
Switch Ports Model SW Version SW Image
* 1 30 WS-C3750X-24 12.2(55)SE5 C3750E-UNIVERSALK9-M
and running "IP services"
but I can't run first command of flexible netflow ( flow record ) this command is not available , so how can i configure !
please HELP
02-18-2014 09:36 PM
Dears
Please ANy update !!!
