Traffic not passing next hop address
andy_4578
For some reason traffic has stopped passing across gi0/2 WAN interface to the next hop of 87.194.168.1, Occasionally i can ping the address but its very intermitent (config attched)
All of the vlans using the WAN link on gi0/2 can no longer get internet access.  No changes have been made and the router/WAN links have been working for over a month.
I was just wondering if its something to do with NAT?? If anyone could help
Hi Andy,
ip route 0.0.0.0 0.0.0.0 81.142.97.107
ip route 0.0.0.0 0.0.0.0 87.194.168.1 2
you are giving a bigger administrative distance to the second route... if you want to use them together you need to write this down :
The NAT looks fine to me. You miss some statement on some interfaces like
interface GigabitEthernet0/0.119
encapsulation dot1Q 119
ip address 10.217.19.254 255.255.255.0
but i don't believe tihs is the issue.
check your routing table and you will better understand what is going on.
Alessio
Extremely important: change all the passwords as soon as you can and remove them from the example!!!!!!!!
I will erase this file from my PC !!!
