Community Member
Traffic not passing next hop address
For some reason traffic has stopped passing across gi0/2 WAN interface to the next hop of, Occasionally i can ping the address but its very intermitent (config attched)
All of the vlans using the WAN link on gi0/2 can no longer get internet access.  No changes have been made and the router/WAN links have been working for over a month.
I was just wondering if its something to do with NAT?? If anyone could help
Everyone's tags (7)
Re: Traffic not passing next hop address
Hi Andy,
ip route
ip route 2
you are giving a bigger administrative distance to the second route... if you want to use them together you need to write this down :
ip route
ip route
The NAT looks fine to me. You miss some statement on some interfaces like
interface GigabitEthernet0/0.119
encapsulation dot1Q 119
ip address
but i don't believe tihs is the issue.
check your routing table and you will better understand what is going on.
Extremely important: change all the passwords as soon as you can and remove them from the example!!!!!!!!
I will erase this file from my PC !!!
