Traffic only going one way on Fiber Module
Hello.
I have 2 switches connected via Cisco Fiber SFP module over a Layer 2 EtherMAN connection.
C3750 and C3750x
Both ports are configured with the same settings, however, a "sh int" command reveals that there are only output packets (no input packets).
This is happening on both connections. What can I try to fix it? See below for interface output and configuration.
Tried changing module to another spare one, and also confirmed with line provider that it is multimode and supports encapsulation.
GigabitEthernet1/0/28 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is xxxxxxxxxxxxxxxxx
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is force-up, media type is 1000BaseSX SFP
  input flow-control is off, output flow-control is unsupported
  Last input 2d08h, output 00:00:00, output hang never
  Last clearing of "show interface" counters 01:39:48
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 3000 bits/sec, 7 packets/sec
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     48510 packets output, 3735808 bytes, 0 underruns
interface GigabitEthernet1/0/28
switchport trunk allowed vlan 1,2,5,6,20
switchport mode trunk
switchport nonegotiate
load-interval 30
speed nonegotiate
srr-queue bandwidth share 1 30 35 5
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
14 Replies 14
devils_advocate
Level 7
Level 7
I assuming you have tried changing the cable itself?
Kyle McKay
This is most commonly seen when the fiber cable polarity is not reversed. Fiber connections do not support auto-MDIX like copper connections do.. that is, they cannot sense whether their neighbor port is transmitting and/or receiving and dynamically change to accommodate.
You must physically match the RX/TX fiber strands. Depending on which type of connector you are using (LC is most common) you would have to physically open it up and reverse the position of the two strands of fiber. This should correct your issue.
Ok.
I will try chaning the RX and TX positions (cant remember if the cable connected would allow me to do that, since it the strand ends are encased in plastic together).
I'll also try changing the cable itself in a few hours, and let you know how it goes.
Most likely it is an issue on the 3750 end (not 3750x).
Just a note, earlier today, on the 3750x end, I tried connecting the TX on the right of the SFP port and the RX on the right, but got no connectivity light or status. But once I swapped it, it came right up.
Thanks again guys for the quick responses.
Hmmm ... Layer 1 and Layer 2 is up on the interface.  I've got a strange feeling this could either be a mis-configuration of the etherchannel (one way traffic) or you are running an IOS which has a bug.
How would I test to see if it is a misconfiguration of etherchannel?
I agree with Leo.
If the interfaces are showing as up/up at both ends it seems very unlikely to
be a physical issue.
Can you post the configs from both ends
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
The most common culprit could be someone did NOT configure etherchannel.  It's like someone connected both links as individual uplink.  So one traffic goes one port and the return traffic comes from another port.
Ok.
Could you give me an example of what I would need to configure on the switch on each end to get the etherchannel going?
I think I'm going way too ahead of myself.
Can you confirm that the link between both switches?  Can you confirm there's only ONE link?  Can you post the following output:
1.  sh cdp neighbor;
2.  sh interface trunk
I can get the output for you in a little while.
But what I can tell you is that there is another working EtherMAN link between these 2 switches, except that this link is only 100Mbps and it is copper. (Same line provider as fiber line that is having issue.)
Port config is same as above config, except speed manually set to 100 and duplex manually set to full.
Last time sh cdp neighbor showed the switches on the copper link, but nothing for the fiber.
Output from 3750 end:
coresw#sh cdp nei
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
                  D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
aplcucm1.localdomain
                 Gig 1/0/7         143               H    7835I3    eth0
SW05.test.com
                 Gig 1/0/22        153              S I   WS-C2960S Gig 1/0/47
SW02.test.com
                 Gig 1/0/23        156              S I   WS-C2960S Gig 1/0/49
SW02.test.com
                 Gig 2/0/23        156              S I   WS-C2960S Gig 1/0/50
SW01.test.com
                 Gig 1/0/24        177              S I   WS-C2960S Gig 1/0/49
SW01.test.com
                 Gig 2/0/24        177              S I   WS-C2960S Gig 1/0/50
aplcucm2         Gig 1/0/10        125               H    Cisco-MCS eth0
kvh-coresw.test.com
                 Gig 2/0/26        122             R S I  WS-C3750X Gig 2/0/24
rtr02.test.com
                 Gig 2/0/18        153             R S I  1812W-P   Fas 9
rtr02.test.com
                 Gig 2/0/15        163             R S I  1812W-P   Fas 1
rtr01.test.com
                 Gig 1/0/18        127             R S I  1812W-P   Fas 9
rtr01.test.com
                 Gig 1/0/15        157             R S I  1812W-P   Fas 1
VGW01.test.com
                 Gig 1/0/2         151             R S I  CISCO2911 Gig 0/1
VGW01.test.com
                 Gig 2/0/2         151             R S I  CISCO2911 Gig 0/2
VGW02.test.com
                 Gig 2/0/8         153             R S I  CISCO2911 Gig 0/2
coresw#sh interface trunk
Port        Mode             Encapsulation  Status        Native vlan
Gi1/0/1     on               802.1q         trunking      1
Gi1/0/28    on               802.1q         trunking      1
Gi2/0/1     on               802.1q         trunking      1
Gi2/0/22    on               802.1q         trunking      1
Gi2/0/26    on               802.1q         trunking      1
Po1         on               802.1q         trunking      1
Po2         on               802.1q         trunking      1
Po3         on               802.1q         trunking      1
Po5         on               802.1q         trunking      1
Port        Vlans allowed on trunk
Gi1/0/1     13,200
Gi1/0/28    1-2,5-6,20
Gi2/0/1     13,20,200
Gi2/0/22    1-2,5-6,20,200
Gi2/0/26    1-2,5-6,20
Po1         1-2,5-6,20
Po2         1-2,5-6,20
Po3         1-2,5-6,20,200
Po5         1-2,5-6,20
Port        Vlans allowed and active in management domain
Gi1/0/1     13,200
Gi1/0/28    1-2,5-6,20
Gi2/0/1     13,20,200
Gi2/0/26    1-2,5-6,20
Po1         1-2,5-6,20
Po2         1-2,5-6,20
Po3         1-2,5-6,20,200
Po5         1-2,5-6,20
Port        Vlans in spanning tree forwarding state and not pruned
Gi1/0/1     13,200
Gi1/0/28    1-2,5-6,20
Gi2/0/1     13,20,200
Gi2/0/26    1-2,5-6,20
Po1         1-2,5-6,20
Po2         1-2,5-6,20
Po3         1-2,5-6,20,200
Po5         1-2,5-6,20
coresw#
Output from 3750x end:
coresw#sh cdp nei
coresw.test.com
                 Gig 2/0/24        145             R S I  WS-C3750G Gig 2/0/26
Gi1/1/1     on               802.1q         trunking      1
Gi2/0/24    on               802.1q         trunking      1
Gi1/1/1     1-2,5-6,20
Gi2/0/24    1-2,5-6,20
Gi1/1/1     1-2,5-6,20
Gi2/0/24    1-2,5-6,20
Gi1/1/1     1-2,5-6,20
Gi2/0/24    1-2,5-6,20
coresw#
Notes
3750 end - Fiber port is 1/0/28, copper port is 2/0/26
3750x end - Fiber port is 1/1/1, copper port is 2/0/24
Judging from the output, I'd say ports 1/0/28 and 2/0/26 are in a etherchannel, possibly Po 1, Po 2 or Po 5.  Can't determine which one until you furnish the output "sh etherchannel <1, 2 or 5> summary".
However, in the 3750X side, there's no ethernchannel being configured.  So I guess this does support my theory that you are getting asymetric traffic due to etherchannel misconfiguration.
I will get you the output soon.
But I did find that if I removed the qos from the fiber line, it comes up.
i also see the same issue on my switches. nothing on fiber copper comes up ok.
if i shut down fiber port on one switch the other end shows down too but not vice versa if i shut down port on switch 2, switch 1 port still shows up.
nothing coming in sh cdp nei
SYD1-ACCS-1101#sh cdp nei | ex Phone
SYD1-CORR-001.executiveboard.com
Gig 2/0/48 130 R S I WS-C4507R Gig 5/46
Gig 1/0/48 130 R S I WS-C4507R Gig 2/46
