Traffic pattern L3 switch link
We need to know the destination traffic pattern (not protocol only subnest) on a particular L3 routed  port on the 4900 series switch.
Traffic source subnets are known, there are few destinations subnets and rest all is internet. ( default )
What we need to know is traffic for each destination subnets that is indirectly each location.
As this switch is not supporting  the netflow commands ( and NBAR) what we could collect with NMS is the total utilization of the intercace.
This is not giving us the required infromation - (traffic per destination).
Is there any way to find out the traffic pattern?
Can we apply "permit" access list on this interface and then check the hits to see the highlevel pattern of the traffic.
Using wireshark was also one option but that will collect too much of data.
show version of the switch is given below.
Please share the experience.
#sh version
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-ENTSERVICESK9-M),  Version 12.2(46)SG, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 27-Jun-08 19:07 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x124746C0
System image file is "bootflash:cat4500e-entservicesk9-mz.122-46.SG.bin"
cisco WS-C4900M (MPC8548) processor (revision 2) with 524288K bytes of memory.
Processor board ID JAE130316SO
MPC8548 CPU at 1.33GHz, Cisco Catalyst 4900M
Last reset from PowerUp
3 Virtual Ethernet interfaces
36 Gigabit Ethernet interfaces
16 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Subodh
1 REPLY
Unfortunately you are right:
Netflow is not supported on Supervisor Engine 6-E and:
To use the NetFlow feature, you must have the Supervisor Engine V-10GE (the functionality is embedded in the supervisor engine), or the NetFlow Services Card (WS-F4531) and either a Supervisor Engine IV or a Supervisor Engine V.
So if you cannot use Netflow and SPAN is not an option (due to high traffic/load), the only
option left is RMON:
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst4500/12.2/40sg/configuration/guide/rmonitor.html
Michael
445
