traffic Shaping on 3560G
I need help to implement the shapping VLAN only on the trunk link between the 6500 and 3560.
I want to reserve:
bandwidth for internet vlan (100mb / s) with a high priority
bandwidth for the MPLS vlan (10 mb / s) with a high priority
Config 3560:
mls qos
vlan internal allocation policy ascending
vlan 201
name MPLS
vlan 202
name internet
class-map match-all IP_TRAFFIC
match access-group 100
class-map match-all TRAFFIC_201
match vlan 201
class-map match-all TRAFFIC_202
match vlan 202
policy-map POLICE_10MO
class TRAFFIC_201
police 10000000 8000 exceed-action drop
policy-map POLICE_100MO
class TRAFFIC_202
police 100000000 8000 exceed-action drop
policy-map VLAN201_POLICY
class IP_TRAFFIC
set precedence 5
service-policy POLICE_10MO
policy-map VLAN202_POLICY
class IP_TRAFFIC
set precedence 4
service-policy POLICE_100MO
interface FastEthernet0/1
switchport mode trunk
mls qos vlan-based
interface Vlan201
no ip address
service-policy input VLAN201_POLICY
interface Vlan202
no ip address
service-policy input VLAN202_POLICY
access-list 100 permit ip any any
end of configuration
Is this corect ? can we do otherwise? All solutions interest me
Traffic shaping and policing are different QoS mechanisms. Shaping buffers or delays traffic in the queue when traffic exceeds a configured threshold. Policers either discard or remark traffic when it exceeds a configured threshold. If you intend to configure policing it can only be applied on a per port or per port/per vlan basis and in the ingress direction. This is similar to the configuration above expect that your child policy can only match on input interfaces.
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst3560/software/release/12.2_55_se/command/reference/cli1.html#wp11904066
Shaping can be configured on the ingress or egress queues. If your goal is to reserve bandwidth for different traffic classes I would mark on ingress and shape on egress. Or maybe per-port/per-vlan policing to your desired rate.
HTH,
Ryan
Follow the steps in this documentation.
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND_40/QoSCampus_40.html#wp1099172
Here is the burst size formual, stick to this:
100MB = 100000000
12500000 = 100000000 / 8
Normal Burst size is for 100MB is: 18750000 = 12500000 X 1.5
Let me know the result.
it's ok on 3760G, but i want to implement the same Shaping on the 6500 in the same Link.
The configuration is the same or not ?
Most likely yes.  Just copy the config and see, if syntax is being recognized by 6500. If it does, it will work on 6500 and then there is IOS version and feature difference as well. You should be familiar with them as well on 6500.
Rizwan Rafeek
Rizwan,
On 6500, it's not possible to match input interface.
They don't want match vlan and apply service-policy in interface vlan.
Re: traffic Shaping on 3560G
Hi Ibellicaud,
do you want to shape traffic or do you want
to prioiritize traffic (queuing) or maybe both?
If you want to reserve bandwitdth for specific traffic you probably want to do some queuing
(in that case the configuration would look different thant that you posted).
Michael
I want to reserve bandwith for specific vlan in port trunk between the 6500 and 3560,
regards,
Laurent
this example configuration should guarantee you 30% bandwidth of the trunk for VLAN 10
and 40% for VLAN 100.
If you also want to limit (and not only guarantee) the bandwitdth you also need the policy statement.
I couldn't test this config in a lab so I don't know if it really does what ist should, but
you can give it a try...
PS Of course you have to have a similiar configuration on the 65000 (at least the trust cos statement)
! enable QoS globally
mls qos
! set trust boundary
interface Gigx/y
desc TRUNK INTERFACE TO 6500
mls qos trust cos
! classify traffic
class-map match-all VLAN10
match vlan 10
class-map match-all VLAN100
match vlan 100
policy-map TAG-VLAN10
class VLAN10
set cos 4 !default map to queue 4
police 10000000 20000 exceed-action drop !ONLY if you want to limit the traffic to 10Mbit/burst size 20KB
policy-map TAG-VLAN100
class VLAN100
set cos 3 !default map to buffer 3
police 100000000 100000 exceed-action drop !ONLY if you want to limit the traffic 100Mbit/burst size 100KB
interface Vlan 10
desc VLAN_INTERFACE
service-policy input TAG-VLAN10
interface Vlan 100
desc VLAN_INTERFACE
service-policy input TAG-VLAN100
interface Gigx/y
desc SWITCHPORT_INTERFACE
mls qos vlan-based
! Allocating buffer space in percent
mls qos queue-set output 1 buffers 15 15 30 40
! Allocating bandwidth in percent, queue 3 is guaranteed 30% and queue is guaranteed 40%
interface Gigx/y
queue-set 1
ssr-queue bandwidth share 15 15 30 40
Michael
1308
