traffic shaping w/ router as a transparent bridge
Ive got some issues with traffic shaping, I assume Im just missing
something silly but cant seem to find the issue. Im hoping some kind
person can point out the obvious
Ive reviewed: Configuring Generic Traffic Shaping
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fqos_c/fqcprt4/qcfgts.htm#wp1001057
... as well as ...
http://www.velocityreviews.com/forums/t30137-using-a-cisco-router-as-a-throttling-bridge.html
http://www.velocityreviews.com/forums/t35922-rate-limit-question.html
http://groups.google.com/group/comp.dcom.sys.cisco/browse_thread/thread/82d477e610269a13/7e8a1f7a26eabee3?lnk=st&q=cisco+traffic+shape+group#7e8a1f7a26eabee3
Heres my network layout:
see attached if this ascii diagram is messed up in the post
hh1 (10.0.0.3 ) |
(0017.0830.cb00) |
h2(10.0.0.4)------ |- (f0/0) r1 (e1/0) --(10.0.0.1) r2 - inet
h2 (10.0.0.5) -----|
i need to shape in and out bound traffic for various hosts
independantly (ie h1, h2, h3). i also need to do this with a bridge
since i dont want to create any more confusion than needed by fooling
with more subnets, consuming extra addresses, or nat. i have a spare
router (r1) which is:
bw_throttle>sh ver
IOS (tm) 3600 Software (C3620-IS-M), Version 12.3(17), RELEASE
SOFTWARE (fc2)
and has the following relevant config:
no ip routing
interface FastEthernet0/0
no ip address
traffic-shape group 1 500000 18000 18000 1000
traffic-shape group 700 500000 18000 18000 1000
bridge-group 1
interface Ethernet1/0
no ip address
bridge-group 1
access-list 1 permit 10.0.0.3
access-list 700 permit 0017.0830.cb00
bridge 1 protocol ieee
this doesn't shape traffic to the expected 500kbps for h1; the only
way i can seem to shape any traffic is with something like the
following on both interfaces
traffic-shape rate 500000 18000 18000 1000
unfortunately this is not what i need; i instead need to shape traffic
for specific hosts, preferably specifiying those hosts by ip address,
not mac address, but at this point ill take whatever i can get
perhaps i just cant do what im trying to pull off? since im trying to
make a router act as a layer 2 device and shape traffic based on layer
3 addresses. perhaps thats not a possibility?
1 REPLY
Re: traffic shaping w/ router as a transparent bridge
Ive not gotten any help with doing this with cisco equipment... though
ive moved on to doing it with BSD
Building a transparent traffic-shaping bridge
http://www.cardus.com/2007/09/24/building-a-transparent-traffic-shaping-bridge/
http://www.openbsd.org/faq/faq4.html
There was a bit more to building the openbsd box, but with some help
from the following I figured it out
http://www.openbsd.org/faq/pf/queueing.html
http://insecure.ucdavis.edu/openbsd/openbsd-4-0-firewall
Things not in the guide were I had to add pftop...
# pkg_add ftp://ftp.openbsd.org/pub/OpenBSD/4.2/packages/i386/pftop-0.6.tgz
and to see queue info once you run pftop you have to use the left and
right arrow keys
I also had to find info on how to change and reapply rules
Configure rules for pf:
write your rules and save them in pf.test
To test your rules type:
# pfctl -nf /etc/pf.test
When you are confident that you want to apply the rules type:
# cp pf.conf pf.old && cp pf.test pf.conf
To load your rules type:
# pfctl -f /etc/pf.conf
Hope that helpls someone. If ayone figures out how to do it with something better
or with cisco equipment id love to know how.
613
