Community Member
traffic within 3750 slow, but fast outside of it
I have 2 new 3750g devices in a small environment.  switch1 acts as our collapsed core and has ip routing enabled, and is connected to a ASA 5510. There are 3 HP l2 switches connected to switch1 as well.   switch2 is simply a server switch.  switch1 and switch2 have a 2port etherchannel between them, and a vlan trunk carrying 4 vlan's.
Issue:  traffic between any 2 hosts on switch2 (same vlan) are slow. (average 300Mbits/sec)  If I move one of those hosts to switch1, speeds increase by 3 times.  (average 900 Mbits/sec).  Additionally, traffic between any 2 hosts on switch1 are quick. testing is done with iperf as well as timing 1gig file transfers.
I don't see any errors or drops anywhere, and there are no other symptoms other than slow transfer beteween hosts on switch2.   Any ideas where to start?  I just got 2 more of these 3750's to put in a 2nd site that we have, put a quick configuration on them, and have the same result.  Other than switch1 having ip routing enabled, the configs are pretty much identical.
thanks
Matt
Everyone's tags (3)
Community Member
running ipbase 12.2(55) se5
Community Member
Re: traffic within 3750 slow, but fast outside of it
Make that se2 not se5. Qos disabled. Cpu utilization is low. Any ideas?
462
