Community Member
Transceiver Modules - Ethernet or Fibre
Are there any performance benefit to using fibre transceiver modules rather than the ethernet GLC-T? The cabling distance is only going to be about 5 metres.
Many thanks
Mark
1 REPLY
Blue
Re: Transceiver Modules - Ethernet or Fibre
In short, No.
You will not have a performance benefit of one over the other.
Fiber can provide much longer paths than copper can but you would not notice a speed enhancement.
Benefits of copper are lower cost, easier termination and it is harder to damage.
106
