transivers duplicate serial numbers
I have a switch WS-C6509-E with supervisor 720 up and running. I inserted a new WS-X6748-SFP module on an empty slot (hot insertion) and after the online diagnostic I received the following error: "%PM_SCP-SP-3-TRANSCEIVER_DUPLICATE: Transceiver in LAN port 4/1 and in LAN port 5/2 have duplicate serial numbers"
00:00:01: BaseBoard Index:152
00:00:01: DaughterBoard Index:208 (Centralized Forwarding Card)
00:00:01: Gemini Rev#: 3
Firmware compiled 31-Aug-05 18:19 by integ Build [100]
00:00:04: %SYS-CFC4-5-RESTART: System restarted --
IOS (tm) c6lc2 Software (c6lc2-SP-M), Version 12.2(18)SXE4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Fri 07-Oct-05 14:15 by kellmill
*Nov 30 00:00:02.731: CFC4: Currently running ROMMON from S (Gold) region
Jul 7 07:52:19 EDT: %DIAG-SP-6-RUN_MINIMUM: Module 4: Running Minimum Diagnostics...
010072: Jul 7 07:52:34 EDT: %SNMP-5-MODULETRAP: Module 4 [Up] Trap
010073: Jul 7 07:52:34 EDT: %MLS_RATE-4-DISABLING: The Layer2 Rate Limiters have been disabled.
Jul 7 07:52:34 EDT: %DIAG-SP-6-DIAG_OK: Module 4: Passed Online Diagnostics
Jul 7 07:52:35 EDT: %PM_SCP-SP-3-TRANSCEIVER_DUPLICATE: Transceiver in LAN port 4/1 and in LAN port 5/2 have duplicate serial numbers
Jul 7 07:52:35 EDT: %OIR-SP-6-INSCARD: Card inserted in slot 4, interfaces are now online
The new module was inserted on slot 4 with an Cisco SFP inserted on port 4/1. The interface gi5/2 is on the supervisor module and isn't a SFP, on this interface the media-type is configured as RJ45 connector.
Mod Ports Card Type Model Serial No.
1 4 SLB Application Processor Complex WS-X6066-SLB-APC SAD09180380
2 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL094234XJ
3 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL09368U1K
4 48 CEF720 48 port 1000mb SFP WS-X6748-SFP SAL1009EXGB
5 2 Supervisor Engine 720 (Hot) WS-SUP720-3B SAD09100ATG
6 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAL09444A3F
7 16 SFM-capable 16 port 1000mb GBIC WS-X6516A-GBIC SAL09253EGY
8 1 SSL Module WS-SVC-SSL-1 SAD091400HN
9 48 48 port 10/100/1000mb EtherModule WS-X6148-GE-TX SAL09169T3W
Mod Sub-Module Model Serial Hw Status
2 Centralized Forwarding Card WS-F6700-CFC SAL09412VWC 2.0 Ok
3 Centralized Forwarding Card WS-F6700-CFC SAL09412PGE 2.0 Ok
4 Centralized Forwarding Card WS-F6700-CFC SAL1006CXA2 2.0 Ok
5 Policy Feature Card 3 WS-F6K-PFC3B SAD090903G8 2.0 Ok
5 MSFC3 Daughterboard WS-SUP720 SAD090901UW 2.3 Ok
6 Policy Feature Card 3 WS-F6K-PFC3B SAL09464ZV4 2.1 Ok
6 MSFC3 Daughterboard WS-SUP720 SAL09444F7S 2.3 Ok
After the error the interface gi5/2 change the status to: GigabitEthernet5/2 is down, line protocol is down (faulty)
We remove the SFP from port 4/1 and “shut/no shut” the interface Gi5/2 and the interface status didn't change.
Dou you have any idea?
Judith
Re: transivers duplicate serial numbers
Judith-
I ran into this problem when we bought some GBIC's from a reseller (or so they said). Come to find out 12 of the 15 we bought had the same serial number. Basically they are gray market products and must be replaced. If you remove one of the offending SFP's and shut/no shut it should bring the interface up. If you have to SFP's with the same serial number, it will shut them both immediately. You can view the serial numbers with a show idprom [options].
Hope it helps.
Thanks Collin, for your advice.
Actually, I removed all SFPs from module 4, also I powered down the module and "shut/no shut" the interface gi5/2 in the supervisor card and the interface continue in the same status
Hardware is C6k 1000Mb 802.3, address is 0011.9201.d83d (bia 0011.9201.d83d)
Description:
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Auto-duplex, Auto-speed, media type is SX
Media-type configured as RJ45 connector
input flow-control is off, output flow-control is off
My next step would be to open a TAC case.
I already did that, they didn't give a clear answer yet, and sent the case to the Experts. :-(
Judith
2847
