Translation between 3750 and 6500 QOS config
We have a new 3750 layer 3 switch installed for a VOIP project. It has the QOS configured, and I need to configure our existing 6513. The 3750 is running 12.4 and the 6513 is running 12.2(17r)SX3. Can someone please help translate the QOS from the 3750 for the 6513? I am not familiar with the QOS configurations (obviously), but I am doing some reading trying to figure this out.
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue input bandwidth 70 30
mls qos srr-queue input threshold 1 80 90
mls qos srr-queue input priority-queue 2 bandwidth 30
mls qos srr-queue input cos-map queue 1 threshold 2 3
mls qos srr-queue input cos-map queue 1 threshold 3 6 7
mls qos srr-queue input cos-map queue 2 threshold 1 4
mls qos srr-queue input dscp-map queue 1 threshold 2 24
mls qos srr-queue input dscp-map queue 1 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue input dscp-map queue 1 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue input dscp-map queue 2 threshold 3 46 47
mls qos srr-queue output cos-map queue 1 threshold 3 4 5
mls qos srr-queue output cos-map queue 2 threshold 1 2
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos srr-queue output dscp-map queue 1 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue output dscp-map queue 1 threshold 3 46 47
mls qos srr-queue output dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 2 threshold 1 26 27 28 29 30 31 34 35
mls qos srr-queue output dscp-map queue 2 threshold 1 36 37 38 39
mls qos srr-queue output dscp-map queue 2 threshold 2 24
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue output dscp-map queue 4 threshold 1 8 9 11 13 15
mls qos srr-queue output dscp-map queue 4 threshold 2 10 12 14
mls qos queue-set output 1 threshold 1 100 100 50 200
mls qos queue-set output 1 threshold 2 125 125 100 400
mls qos queue-set output 1 threshold 3 100 100 100 400
mls qos queue-set output 1 threshold 4 60 150 50 200
mls qos queue-set output 1 buffers 15 25 40 20
mls qos
Thanks for any help someone can offer.
1 REPLY
I found documentation which indicated to add auto qos to each interface. I then added the following to each interface:
auto qos voip trust
mls qos trust dscp
It added configs for COS queuing, but I can't seem to find the DSCP queuing commands. Do I need to tweak the default commands?
wrr-queue bandwidth 50 255
wrr-queue queue-limit 75 15
wrr-queue random-detect min-threshold 2 70 100
wrr-queue random-detect max-threshold 2 90 100
wrr-queue cos-map 1 2 0
wrr-queue cos-map 2 1 1 2 3 4
wrr-queue cos-map 2 2 6 7
rcv-queue cos-map 1 1 0
rcv-queue cos-map 1 3 1 2 3 4
rcv-queue cos-map 1 4 6 7
mls qos trust dscp
auto qos voip trust
What would be the commands (if any) for the DSCP items?
403
