Community Member
transport PAgP over dot1q tunnel
Hi all,
I have a Catalyst 4507 with SUP7L-E running cat4500e-universalk9.SPA.03.03.00.SG.151-1.SG.bin.
The network diagram is attached.
I'm trying to transport PAgP over dot1q tunnel but PAgP packets are not carried from one site to the other on any direction.
The configuration on 4500 interfaces is:
interface GigabitEthernetx/y
switchport access vlan X
switchport mode dot1q-tunnel
l2protocol-tunnel cdp
l2protocol-tunnel lldp
l2protocol-tunnel stp
l2protocol-tunnel vtp
I cannot find the command 'l2protocol-tunnel point-to-point pagp'. Is it supported?
I did the same test with LACP but it didn't work.
Can you help me?
Stefano
1 REPLY
Community Member
Re: transport PAgP over dot1q tunnel
Network diagram attached
270
