trouble accessing secondary ip block added to interface vlan on msfc
trouble accessing secondary ip block added to interface vlan on msfc I have a customer that wants to add a secondary ip block to existing primary ip block on interface vlan but, they are using hsrp when i added the secondary ip block to there existing interface vlan they are not able to access the secondary ip block nor am i able to ping any ip with the block accept for the ip address that is added to the interface vlan is this possible to do i need help with this please
1 REPLY
Re: trouble accessing secondary ip block added to interface vlan
Jarrett,
You can use secondary IP's in HSRP too. See below for an example.
Router A
interface Vlan1
ip address 10.0.2.2 255.255.255.0 secondary
ip address 10.0.1.1 255.255.255.0
Router B
interface vlan1
ip address 10.0.2.3 255.255.255.0 secondary
ip address 10.0.1.3 255.255.255.0
HSRP commands
standby 1 ip 10.0.1.1
standby 1 ip 10.0.2.1 secondary
standby 1 preempt
standby 1 priority 130
Hope this helps!
Mark
112
