Trouble port fowarding 2821
I have a Linksys RV082(port fowarded on all ports i need port fowarded to 192.168.0.102) this then goes through a transparent firewall, and to a 2821(external ip 192.168.0.102) the configs are posted below for the 2821 and the firewall
Firewall config:
Result of the command: "show running-config"
: Saved
ASA Version 7.0(8)
firewall transparent
hostname ciscoasa
domain-name default.domain.invalid
enable password 6efABQ2cPmP7OKuA encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
dns-guard
interface Ethernet0/0
nameif inside
security-level 100
interface Ethernet0/1
nameif outside
security-level 0
interface Ethernet0/2
shutdown
no nameif
no security-level
interface Management0/0
nameif management
security-level 100
management-only
banner exec All your base are belong to us!
banner login All your base are belong to us!
banner motd All your base are belong to us!
ftp mode passive
access-list outside_access_in extended permit tcp any eq 5001 any eq 5001
pager lines 24
mtu inside 1500
mtu outside 1500
mtu management 1500
asdm image disk0:/asdm-508.bin
no asdm history enable
arp timeout 14400
access-group outside_access_in in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
username mebernstein password awdhlGZ6rAWbpyEZ encrypted privilege 15
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect mgcp
inspect pptp
inspect ctiqbe
inspect snmp
inspect http
inspect icmp
inspect ils
service-policy global_policy global
Cryptochecksum:079bfac43742cef7ff12ec4f03adf068
: end
Re: Trouble port fowarding 2821
Router config:
Building configuration...
Current configuration : 8330 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname CiscoRouter
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200
logging console critical
enable secret 5 $1$QKvL$DNWm2th4qX.xx2vb1hmG1/
enable password 7 047A1E011A32581F5F
aaa new-model
aaa authentication login default local
aaa authentication login local_authen local
aaa authorization exec default local
aaa authorization exec local_author local
aaa session-id common
dot11 syslog
no ip source-route
no ip gratuitous-arps
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.4.1 192.168.4.9
ip dhcp excluded-address 192.168.4.200 192.168.4.254
ip dhcp pool LAN_POOL
import all
network 192.168.4.0 255.255.255.0
default-router 192.168.4.1
lease 15
ip dhcp pool HP_PRINTER
host 192.168.4.114 255.255.255.0
hardware-address 000d.9d1c.101a ieee802
no ip bootp server
ip domain name globalsource.com
ip name-server 192.168.0.1
ip port-map user-protocol--2 port tcp 20570
ip port-map user-protocol--3 port tcp 20572
ip port-map user-protocol--1 port tcp 5001
ip port-map user-protocol--4 port tcp 20571
voice-card 0
no dspfarm
username mebernstein privilege 15 view root secret 5 $1$JDyK$M5pRwUdDYFBP7K27/2OSs.
archive
log config
hidekeys
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
class-map type inspect match-all sdm-nat-user-protocol--4-2
match access-group 109
match protocol user-protocol--4
class-map type inspect match-all sdm-nat-user-protocol--4-1
match access-group 104
class-map type inspect match-all sdm-nat-user-protocol--3-1
match access-group 103
match protocol user-protocol--3
class-map type inspect match-all sdm-nat-user-protocol--2-1
match access-group 102
match protocol user-protocol--2
class-map type inspect match-all sdm-nat-user-protocol--1-2
match access-group 106
match protocol user-protocol--1
class-map type inspect match-all sdm-nat-user-protocol--1-1
match access-group 101
class-map type inspect match-all sdm-nat-user-protocol--2-2
match access-group 107
class-map type inspect match-all sdm-nat-user-protocol--3-2
match access-group 108
class-map type inspect match-any sdm-cls-insp-traffic
match protocol cuseeme
match protocol dns
match protocol ftp
match protocol h323
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp extended
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all sdm-insp-traffic
match class-map sdm-cls-insp-traffic
class-map type inspect match-any SDM-Voice-permit
match protocol h323
match protocol skinny
match protocol sip
class-map type inspect match-any sdm-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
sdm-icmp-access
match class-map sdm-cls-icmp-access
class-map type inspect match-all sdm-invalid-src
match access-group 100
class-map type inspect match-all sdm-protocol-http
match protocol http
policy-map type inspect sdm-permit-icmpreply
class type inspect sdm-icmp-access
inspect
class class-default
pass
policy-map type inspect sdm-pol-NATOutsideToInside-1
class type inspect sdm-nat-user-protocol--1-1
inspect
class type inspect sdm-nat-user-protocol--2-1
inspect
class type inspect sdm-nat-user-protocol--3-1
inspect
class type inspect sdm-nat-user-protocol--4-1
inspect
class type inspect sdm-nat-user-protocol--1-2
inspect
class type inspect sdm-nat-user-protocol--2-2
inspect
class type inspect sdm-nat-user-protocol--3-2
inspect
class type inspect sdm-nat-user-protocol--4-2
inspect
class class-default
policy-map type inspect sdm-inspect
class type inspect sdm-invalid-src
drop log
class type inspect sdm-insp-traffic
inspect
class type inspect sdm-protocol-http
inspect
class type inspect SDM-Voice-permit
inspect
class class-default
pass
class class-default
drop log
zone security out-zone
zone security in-zone
zone-pair security sdm-zp-self-out source self destination out-zone
service-policy type inspect sdm-permit-icmpreply
zone-pair security sdm-zp-NATOutsideToInside-1 source out-zone destination in-zone
service-policy type inspect sdm-pol-NATOutsideToInside-1
zone-pair security sdm-zp-out-self source out-zone destination self
zone-pair security sdm-zp-in-out source in-zone destination out-zone
service-policy type inspect sdm-inspect
interface Null0
no ip unreachables
interface GigabitEthernet0/0
description $ETH-LAN$$FW_INSIDE$
ip address 192.168.4.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
zone-member security in-zone
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
description $ETH-WAN$$FW_OUTSIDE$
ip address dhcp client-id GigabitEthernet0/1
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
zone-member security out-zone
ip route-cache flow
duplex auto
speed auto
no mop enabled
router rip
network 192.168.0.0
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.0.1 permanent
ip http server
ip http access-class 3
no ip http secure-server
ip nat inside source static tcp 192.168.4.254 5001 interface GigabitEthernet0/1 5001
ip nat inside source list 2 interface GigabitEthernet0/1 overload
ip nat inside source static tcp 192.168.4.38 20570 interface GigabitEthernet0/1 20570
ip nat inside source static tcp 192.168.4.38 20572 interface GigabitEthernet0/1 20572
ip nat inside source static tcp 192.168.4.38 20571 interface GigabitEthernet0/1 20571
ip access-list extended Permit_all_ports
remark SDM_ACL Category=1
permit tcp any any eq 20570 log
logging trap debugging
access-list 1 remark INSIDE_IF=GigabitEthernet0/0
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.4.0 0.0.0.255
access-list 2 remark SDM_ACL Category=2
access-list 2 permit 192.168.4.0 0.0.0.255
access-list 3 remark HTTP Access-class list
access-list 3 remark SDM_ACL Category=1
access-list 3 permit 192.168.4.0 0.0.0.255
access-list 3 deny any
access-list 100 remark SDM_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 101 remark SDM_ACL Category=0
access-list 101 permit ip any host 192.168.4.254
access-list 102 remark SDM_ACL Category=0
access-list 102 permit ip any host 192.168.4.38
access-list 103 remark SDM_ACL Category=0
access-list 103 permit ip any host 192.168.4.38
access-list 104 remark SDM_ACL Category=0
access-list 104 permit ip any host 192.168.4.38
access-list 105 remark VTY Access-class list
access-list 105 remark SDM_ACL Category=1
access-list 105 permit ip 192.168.4.0 0.0.0.255 any
access-list 105 deny ip any any
access-list 106 remark SDM_ACL Category=0
access-list 106 permit ip any host 192.168.4.254
access-list 107 remark SDM_ACL Category=0
access-list 107 permit ip any host 192.168.4.38
access-list 108 remark SDM_ACL Category=0
access-list 108 permit ip any host 192.168.4.38
access-list 109 remark SDM_ACL Category=0
access-list 109 permit ip any host 192.168.4.38
no cdp run
control-plane
banner login ^CAll your base are belong to us!
^C
line con 0
transport output telnet
line aux 0
line vty 0 4
access-class 105 in
password 7 080079693C2A314644
login authentication local_authen
transport input telnet ssh
scheduler allocate 20000 1000
end
129
