05-24-2014 02:28 AM - edited 03-07-2019 07:31 PM
Hello, I've recently received some cisco routers and switches and I've been trying to teach myself how to configure them. Right now my setup is as follow.
ISP Router -> Cisco 2811 Router -> Cisco 2950 Switch -> Hosts
While connected through the console port on my cisco router I'm able to ping to my outside ip address as well as all my inside ip addresses. I'm also able to ping google.com.
This is where my problems start. When I'm sitting on my host pc I'm able to ping my outside ip address as well as my inside ip addresses but I have no internet connectivity so I can't ping google.com.
I have my cisco router setup to handout addresses through DHCP(192.168.1.0 network 255.255.255.0 subnet mask). My host PC is receiving an ip address of 192.168.1.100, subnet mask 255.255.255.0, default gateway 192.168.1.1, dns 192.168.1.1.
Im unsure how to go about fixing this issue. If I could get some advice I'd really appreciate it.
Show run(Cisco Router)
Building configuration...
Current configuration : 1389 bytes
version 15.1
hostname SeattleR1
boot-start-marker
boot-end-marker
no logging on
enable secret 5 $1$J/SN$EYHwGE3/xjyK5z7QVh9/g1
aaa new-model
aaa session-id common
memory-size iomem 20
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 192.168.1.1 192.168.1.99
ip dhcp pool mypool
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 192.168.1.1
ip domain name SeattleR1.com
license udi pid CISCO2811 sn FTX1103A4FV
username admin password 7 104D000A0618
redundancy
interface FastEthernet0/0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
no fair-queue
clock rate 125000
interface Serial0/0/1
no ip address
shutdown
clock rate 125000
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.0.0.1
control-plane
line con 0
password 7 01100F175804
line aux 0
line vty 0 4
password 7 110A1016141D
transport input ssh
scheduler allocate 20000 1000
end
05-24-2014 02:50 AM
Here is my show running-config for my cisco switch.
Current configuration : 1564 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname SeattleSW1
aaa new-model
enable secret 5 $1$69vB$L./pEEpM.IzIYfFhz45BW.
username admin password 7 13061E010803
ip subnet-zero
ip domain-name SeattleSW1.com
no ip address
interface FastEthernet0/2
no ip address
interface FastEthernet0/3
no ip address
interface FastEthernet0/4
no ip address
interface FastEthernet0/5
no ip address
interface FastEthernet0/6
no ip address
interface FastEthernet0/7
no ip address
interface FastEthernet0/8
no ip address
interface FastEthernet0/9
no ip address
interface FastEthernet0/10
no ip address
interface FastEthernet0/11
no ip address
interface FastEthernet0/12
no ip address
interface FastEthernet0/13
no ip address
interface FastEthernet0/14
no ip address
interface FastEthernet0/15
no ip address
interface FastEthernet0/16
no ip address
interface FastEthernet0/17
no ip address
interface FastEthernet0/18
no ip address
interface FastEthernet0/19
no ip address
interface FastEthernet0/20
no ip address
interface FastEthernet0/21
no ip address
interface FastEthernet0/22
no ip address
interface FastEthernet0/23
no ip address
interface FastEthernet0/24
no ip address
interface Vlan1
ip address 192.168.1.2 255.255.255.0
no ip route-cache
ip http server
line con 0
password 7 060506324F41
line vty 0 4
password 7 121A0C041104
line vty 5 15
end
05-24-2014 03:42 AM
Can you provide the ip addressing of your router WAN interfaces?
05-24-2014 04:50 AM
outside ip address 50.149.69.XXX
inside ip address 10.0.0.1 subnet 255.255.255.0
primary dns 75.75.75.75
secondary dns 75.75.76.76
06-04-2014 08:00 AM
OK so there is no NAT configured on your router so if you can PING out to the internet I assume the ISP router is doing that for you?
Also you have a default route to 10.0.0.1, I assume FastEthernet0/1 is connected to your ISP router and it is getting a 10.0.0.X address via DHCP?
I think it's not working because your ISP router does not know about the 192.168.1.0/24 network. You would need to set a static 10.0.0.X address on your router then ask your ISP to add a static route to your 192. network via this 10. address.
Hope that helps!
Matty
05-26-2014 11:45 AM
If there's any other information I could provide that could help get my issue resolved I'll gladly provide it. I really want to figure how to fix it.
