Trunk between 4500-X and 4507R not working
T.Ratschkowski
Hi all,
i have got a new switch (4500-X) which i would like to connect to our existing 4507R switch. So i configured trunk ports on each of them, like i do this with all of my other access switches. I tried so many things, but i cant reach vlans from the new switch and iam totaly out of ideas
Iam quite sure that i make a verry dump config issue, but i cant fine the fault in my config...hopyfully someone could please help me? I hope this is the right information you need.
Many many Thanks!
The "OLD" Switch (4507R):
OLD#sh ver
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-IPBASEK9-M), Version 12.2(54)SG, RELEASE SOFTWARE (fc3)
OLD#sh run int gi3/6
Building configuration...
Current configuration : 149 bytes
interface GigabitEthernet3/6
switchport mode trunk
switchport nonegotiate
end
OLD#sh int gi3/6 switch
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: Off
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
OLD#sh int gi3/6 trunk
Port        Mode             Encapsulation  Status        Native vlan
Gi3/6       on               802.1q         trunking      1
Port        Vlans allowed on trunk
Gi3/6       1-4094
Port        Vlans allowed and active in management domain
Gi3/6       1-3,9-10,20,23-24,26,32-40,66-68,95-101,110-111,120,200,500-501,510,995-999
Port        Vlans in spanning tree forwarding state and not pruned
Gi3/6       1
The "NEW" Switch (4500-X):
NEW#sh ver
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.04.00.SG RELEASE SOFTWARE (fc3)
NEW#sh run int te1/32
Current configuration : 94 bytes
interface TenGigabitEthernet1/32
end
NEW#sh int te1/32 switchport
Switchport: Enabled
Negotiation of Trunking: On
Voice VLAN: none
NEW#sh int te1/32 trun
Te1/32      on               802.1q         trunking      1
Te1/32      1-4094
Te1/32      1-3,9-10,20,23-24,26,32-40,66-68,95-101,110-111,120,200,500-501,510,995-999
Tobias
The ip default-gateway command on the new switch should allow it to talk to the old switch L3 vlan interfaces. The docs for the 4500-X however are a little vague in terms of when you need to use a static route. Can you add this to your new switch and see if it changes anything -
ip route 0.0.0.0 0.0.0.0 10.98.0.254
Jon
13 Replies 13
Mark Yeates
Level 7
Level 7
Tobias,
The reason the trunk is not coming up is becasue you have a 1G interface connecting to a 10G. Try connecting a 1G to 1G or 10G to 10G. You cannot connect these interfaces at different speeds.
HTH,
Mark
Mark,
in both ports are only 1G gbics..i thought that should work?
tobias
Hi Tobias,
If you want to set up the link , try to set speed of the Te interface manually to 1000:
Int te1/32
Speed 1000
Switchport nonegotiate
And if would be necessary, do the dame on interface gi3/6:
Int gi3/6
Speed 1000
Be sure that the TenGigaEthernet module is 1G/10G compliant.
Good luck.
Best regards.
Hello
1. The 4500x has dual purpose UPLINKS, they can be either 10gig or 1gig, the speed is auto-detected.
Tobias.
Either the interface is down, down; Or there is a problem with spanning-tree.
- The problem is spanning-tree, vlans in forwarding state: vlan 1 only. So even when other vlans are allowed to cross the trunk STP is forwarding in that instance.
Gi3/6       1-4094
Gi3/6       1
- Now in the new switch, all vlans are allowed and forwarding.
Te1/32      1-4094
I have seen this issue before, when one switch is in vtp transparent and the other is either client or server. Can you share the output of the command show vtp status for both switches.
Regards.
Wilson B.
!Please rate useful post.
Hello Wilson,
sorry for the late reply. Following are the two outputs:
OLD#sh vtp stat
VTP Version capable             : 1 to 3
VTP version running             : 1
VTP Domain Name                 : domain99
VTP Pruning Mode                : Enabled
VTP Traps Generation            : Disabled
Device ID                       : 000c.30b1.7540
Configuration last modified by 10.98.0.254 at 6-17-13 11:52:16
Local updater ID is 10.98.0.254 on interface Vl1 (lowest numbered VLAN interface found)
Feature VLAN:
VTP Operating Mode                : Server
Maximum VLANs supported locally   : 1005
Number of existing VLANs          : 44
Configuration Revision            : 59
MD5 digest                        : 0xAF 0xE7 0xA6 0x16 0xA3 0xED 0xFE 0xBC
                                    0x5C 0xF6 0x51 0xE4 0x23 0x5C 0xF8 0x9F
NEW#sh vtp stat
Device ID                       : f872.ead8.4400
Feature VLAN:
VTP Operating Mode                : Client
Tobias
Can you post "sh spanning-tree vlan 3" from each switch
Are both interfaces showing as up/up ?
Jon
Hi!
Yes, sure:
######### OLD ##########
OLD#sh spanning-tree vlan 3
VLAN0003
  Spanning tree enabled protocol ieee
  Root ID    Priority    32771
             Address     000c.30b1.7540
             This bridge is the root
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32771  (priority 32768 sys-id-ext 3)
             Aging Time  300 sec
Interface           Role Sts Cost      Prio.Nbr Type
Gi3/5               Desg FWD 4         128.133  P2p
Gi3/6               Desg FWD 4         128.134  P2p
Gi4/2               Desg FWD 4         128.194  P2p
Gi4/3               Desg FWD 4         128.195  P2p
Gi5/1               Desg FWD 4         128.257  P2p
Gi5/3               Desg FWD 4         128.259  P2p
Gi5/4               Desg FWD 4         128.260  P2p
Gi5/5               Desg FWD 4         128.261  P2p
Gi5/6               Desg FWD 4         128.262  P2p
Gi6/1               Desg FWD 4         128.321  P2p
Gi6/2               Desg FWD 4         128.322  P2p
Gi6/3               Desg FWD 4         128.323  P2p
Gi6/5               Desg FWD 4         128.325  P2p
Gi6/6               Desg FWD 4         128.326  P2p
Gi7/1               Desg FWD 4         128.385  P2p
Gi7/2               Desg FWD 4         128.386  P2p
Gi7/4               Desg FWD 4         128.388  P2p
Gi7/5               Desg FWD 4         128.389  P2p
Gi7/6               Desg FWD 4         128.390  P2p
Po3                 Desg FWD 3         128.643  P2p
Po6                 Desg FWD 3         128.646  P2p
Po7                 Desg FWD 3         128.647  P2p
OLD#sh int gi3/6
GigabitEthernet3/6 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet Port, address is 0016.9dd4.1fe7 (bia 0016.9dd4.1fe7)
  Description: trunk core NEU
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseSX
  Media-type configured as SFP connector
  input flow-control is on, output flow-control is off
  Last input 00:00:04, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 9000 bits/sec, 16 packets/sec
     809802 packets input, 156747108 bytes, 0 no buffer
     Received 809180 broadcasts (809157 multicasts)
     77368681 packets output, 5652973144 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
     0 lost carrier, 0 no carrier
######### NEW ##########
NEW#sh spanning-tree vlan 3
VLAN0003
             Cost        4
             Port        32 (TenGigabitEthernet1/32)
             Address     f872.ead8.4400
             Aging Time  300 sec
Te1/32              Root FWD 4         128.32   P2p
NEW#sh int ten 1/32
TenGigabitEthernet1/32 is up, line protocol is up (connected)
  Hardware is Ten Gigabit Ethernet Port, address is f872.ead8.441f (bia f872.ead8.441f)
  Description: trunk sw99rz1-1-1
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  input flow-control is on, output flow-control is on
  Last input 00:00:00, output never, output hang never
  5 minute input rate 13000 bits/sec, 18 packets/sec
     365663 packets input, 26752705 bytes, 0 no buffer
     Received 365496 broadcasts (363520 multicasts)
     3843 packets output, 745065 bytes, 0 underruns
     0 unknown protocol drops
Thanks a lot!
tobias
Tobias
That looks fine, STP BPDUs are certainly going across the link because the new switch recognises the old switch as STP root for vlan 3.
When you say you can't reach vlans how exactly are you testing this ?
Can you post a "sh vlan brief" from the new switch ?
Jon
Hi and thanks for your time!
I cant reach non of the vlan interfaces configured on the OLD switch, only vlan1 interface.
I attach the config from OLD switch (NEW switch is connected to GI3/6) and NEW switch.
VLAN on NEW switch:
NEW#sh vlan brief
VLAN Name                             Status    Ports
1    default                          active    Te1/1, Te1/2, Te1/3, Te1/4
                                                Te1/5, Te1/6, Te1/7, Te1/8
                                                Te1/9, Te1/10, Te1/11, Te1/12
                                                Te1/13, Te1/14, Te1/15, Te1/16
                                                Te1/17, Te1/18, Te1/19, Te1/20
                                                Te1/21, Te1/22, Te1/23, Te1/24
                                                Te1/25, Te1/26, Te1/27, Te1/28
                                                Te1/29, Te1/30, Te1/31, Te2/1
                                                Te2/2, Te2/3, Te2/4, Te2/5
                                                Te2/6, Te2/7, Te2/8
2    default_Data_Vlan                active
3    RZ1-nonServer_Vlan               active
9    snsmon                           active
10   VoIP                             active
20   DSL-ROUTER-EXTERN                active
23   Euras-RZ1                        active
24   Euras-Client-Transit             active
26   IP-Kameras                       active
32   Access_CC                        active
33   ACCESS_BUHA                      active
34   ACCESS_HALLE5                    active
35   Access_Halle4                    active
36   Access_Halle1                    active
37   Access_Halle3                    active
38   Access_RZ1                       active
39   Access_GM                        active
40   NH3+4                            active
66   Shop/Logistik                    active
67   Webfacing                        active
68   LotusMail                        active
95   DatabaseServer                   active
96   VMware-Netz                      active
97   Storage-Vlan                     active
98   Management-Vlan                  active
99   SERVER-RZ1                       active
100  bladetest                        active
101  WLAN_101_Scanner                 active
110  i5-HMC                           active
111  i5-HMC2                          active
120  Mysql_Replication                active
200  AP-WLC-Vlan                      active
500  DMZ                              active
501  Guest-Vlan                       active
510  DMZ2                             active
995  Shop_Cluster_Vlan                active
996  I-Series_Blade-Vlan              active
997  Blade_Management                 active
998  I5_SYNCLINK                      active
999  Euras_Transit                    active
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
Tobias
Jon
YOU ARE MY HERO
It works now, all is working as it should be!
Many Thanks Jon!!
Hello
Would you please mark this discussion as correct and rate it so others may be able to benefit from the answer provided by JON
res
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
You have seen an issue where the trunk will not form if one switch is in transparent and the other in Client? I am having an issue with a trunk forming across a metro ethernet connection. One of the switches is in transparent mode and the other client.
