Trunk issue on 4500 switch
Hi ,
I am facing issues creating trunk between twi 4500 switches on ehernet port.
following is the configuration:
Switch 1 :
interface GigabitEthernet2/3
switchport mode trunk
logging event link-status
Switch: cisco WS-C4506-E
Module:WS-X4548-GB-RJ45V
Sup:Supervisor V
Switch 2 :
interface FastEthernet3/48
Switch: WS-C4506
Module: WS-X4248-RJ45V
Sup:Supervisor II+
Interface shows down down. Checked cable its fine. Trunk is formed with same cable with a 3750 switch at one end.
Kindly suggest.
Hall of Fame Super Blue
Re: Trunk issue on 4500 switch
What type of cable are you using ? If it is copper and a straight-thru try using a crossover cable.
Jon
Recommendation is not to leave the configuration in auto due to it could cause conflicts,the best option would be hardcode the configuration depending on your
requirements (mode access, mode trunk).
Now I understand that we have a connection between 2 4500 switches, in this case please provide me with the configuration from both ports also pleaseprovide me the following captures
Show interfaces gig x/y
Show interfaces trunk ----�om both switches
Show module-- both switches
Please let me know if you are able to try another cable, another port on both sites of the link.
syed
499
