Trunk ports are not passing traffic through correctly
We have a Cisco 2801 plugged in to a CAT2950 switch. The router IOS is c2801-advipservicesk9-mz.124-8c.bin and the switch IOS is c2950-i6q4l2-mz.121-22.EA9.bin.
When the devices are reset/reloaded the state of the link between the devices comes up but CRC errors are shown on the switch port and there is 80-90% packet loss.
If a different switch port is used the problem still occurs. The router interface is fastethernet0/1 and the switch interface is fastethernet0/3.
The only way to stop the errors is to manually shutdown and then open the interfaces.
Switch Port
interface FastEthernet0/3
description **** Trunk link to router FastEthernet0/1 ****
switchport trunk allowed vlan X,X,X
switchport mode trunk
speed 100
duplex full
Router port
interface FastEthernet0/1
description Trunk to Switch FastEthernet 0/3
no ip address
no ip route-cache cef
no ip route-cache
no ip split-horizon
speed 100
full-duplex
Re: Trunk ports are not passing traffic through correctly
Hi Friend,
You have configured trunk on switch but have you configured any subinterfaces on routers with encapsulation and dot1q? Also can you remove manual speed and duplex settings and keep them as auto auto?
Ankur
hi mayam can u post the output of the show interface trunk command?
bye flash
174
