12-29-2011 01:08 AM - edited 03-07-2019 04:05 AM
I'm trying to trunk Fa0/3 port of 3524XL switch and Gi0/1 port of 3650G, below are the commands used.
In Cisco 3524XL:
# interface FastEthernet0/3
description uplink to 3560
port group 1
switchport mode trunk
end
In Cisco 3560:
# interface GigabitEthernet0/1
description trunk port to 3524
no ip address
switchport nonegotiate
channel-group 1 mode on
end
#interface Port-channel1
no ip address
end
The issue is VTP not getting propogated into the Cisco 3650G switch so I'm not getting the VLAN database from my Cisco Core Switch 6500. Am I missing anything in the configuration???
12-29-2011 02:21 AM
Hi Rahul,
EtheEtherChannel bundles can consist of up to eight physical ports of the same Ethernet media
type and speed. Some configuration restrictions exist to ensure that only similarly
configured links are bundled.
Generally, all bundled ports first must belong to the same VLAN. If used as a trunk, bundled
ports must be in trunking mode, have the same native VLAN, and pass the same set
of VLANs. Each of the ports should have the same speed and duplex settings before being
bundled. Bundled ports also must be configured with identical spanning-tree settings.
Check portchannel interface configuration..
Prajith
12-29-2011 02:34 AM
So your VTP isn't propagating? Did you specify the VTP domain and VTP password? What is the VTP mode?
Speed should be fine because the 3560G can negotiate to 100 mbps.
