03-22-2007 07:32 AM - edited 03-05-2019 03:03 PM
I have a loop of 3550s that do trunking between each other because I need 10 LANs that cant talk to each other and I figured it would be alot easier to do this than setup a bunch of ACLs in each switch and do routing. The question I have is that I have a remote site that I have now put wireless into that runs at 72MBps. Is this a sufficient speed for trunking? It would come in handy to have all the VLANs at this remote site.
Solved! Go to Solution.
03-25-2007 01:27 AM
Then you should be fine. As i say make sure you enable vtp pruning as this will cut down on unnecessary traffic.
Jon
03-24-2007 07:10 PM
anyone?
03-24-2007 07:21 PM
So is your remote site connected at Layer 2. If so then i can't see an issue with running trunking across the link. It is more to do with the amount of data that will go down the link.
It would be worthwhile pruning any vlans that you do not need at your remote site if there are any.
Jon
03-24-2007 07:35 PM
yes layer two?
03-25-2007 01:27 AM
Jon
