Trunking not replicating vlans?
I have two switches, a 2960 (sw01) and a 2948 (sw02). The sw01 is trunking via dot1q on Gi0/24 to sw02 on 2/48. Why are VLANs 2-4 not active on sw02?
sw01#sh int Gi0/24 trunk
Port        Mode         Encapsulation  Status        Native vlan
Gi0/24      auto         802.1q         trunking      1
Port        Vlans allowed on trunk
Gi0/24      1-4094
Port        Vlans allowed and active in management domain
Gi0/24      1-4,100
Port        Vlans in spanning tree forwarding state and not pruned
Gi0/24      1-4,100
sw01#
sw02> (enable) sh trunk
* - indicates vtp domain mismatch
# - indicates dot1q-all-tagged enabled on the port
2/48     desirable    dot1q          trunking      1
2/48     1-1005,1025-4094
2/48     1
2/48     1
sw02> (enable)
sw01#sh vlan
VLAN Name                             Status    Ports
1    default                          active    Gi0/3, Gi0/4, Gi0/5, Gi0/6
                                                Gi0/8, Gi0/9, Gi0/10, Gi0/11
                                                Gi0/12, Gi0/13, Gi0/14, Gi0/16
2    VLAN0002                         active    Gi0/18, Gi0/19, Gi0/20
3    VLAN0003                         active    Gi0/15, Gi0/17, Gi0/21, Gi0/22
                                                Gi0/23
4    VLAN0004                         active    Gi0/1, Gi0/2, Gi0/7
100  iSCSI-Data                       active
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
2    enet  100002     1500  -      -      -        -    -        0      0
3    enet  100003     1500  -      -      -        -    -        0      0
4    enet  100004     1500  -      -      -        -    -        0      0
100  enet  100100     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 tr    101003     1500  -      -      -        -    -        0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trnet 101005     1500  -      -      -        ibm  -        0      0
Remote SPAN VLANs
Primary Secondary Type              Ports
sw01#
sw02> (enable) set vlan 2 2/3
VLAN  Mod/Ports
2     2/3
Vlan 2 is not active.
sw02> (enable)
Everyone's tags (2)
1 ACCEPTED SOLUTION
Purple
Re: Trunking not replicating vlans?
  Neither one has a vtp domain name .  Try adding  domain name to both and see what happens .  Both sides need the same vtp domain name . Make sure it matches whatever you are using for the server vtp names.
sw02> (enable) sh vlan
VLAN Name                             Status    IfIndex Mod/Ports, Vlans
1    default                          active    4       2/1-2,2/4-47,2/49-52
1002 fddi-default                     active    5
1003 token-ring-default               active    8
1004 fddinet-default                  active    6
1005 trnet-default                    active    7
VLAN Type  SAID       MTU   Parent RingNo BrdgNo Stp  BrdgMode Trans1 Trans2
1003 trcrf 101003     1500  -      -      -      -    -        0      0
1004 fdnet 101004     1500  -      -      -      -    -        0      0
1005 trbrf 101005     1500  -      -      -      ibm  -        0      0
VLAN AREHops STEHops Backup CRF 1q VLAN
1003 7       7       off
sw02> (enable)
Purple
  It appears that your client server setup is not working between devices .  The vtp setup is incorrectly configured on one side or the other .  You would have to post the vtp information from both sides so that we could see .  Probably Sw 2 is a client and a client cannot create a vlan , it has to see those vlans from the vtp server.  VTP is what propagates the vlans from server to any vtp clients.
Hey again glen, thanks for the help yesterday. These are the same switches, just moving on the next issue. Is this what you need?
sw01#sh vtp status
VTP Version                     : 2
Configuration Revision          : 7
Maximum VLANs supported locally : 255
Number of existing VLANs        : 9
VTP Operating Mode              : Server
VTP Domain Name                 :
VTP Pruning Mode                : Disabled
VTP V2 Mode                     : Disabled
VTP Traps Generation            : Disabled
MD5 digest                      : 0x63 0xA9 0x10 0xDE 0xC1 0x38 0xA7 0x97
Configuration last modified by 192.168.1.130 at 12-12-95 02:50:03
Local updater ID is 192.168.1.130 on interface Vl1 (lowest numbered VLAN interface found)
sw01#
sw02> (enable) sh vtp domain
Version      : running VTP1 (VTP3 capable)
Domain Name  :                                  Password  : not configured
Notifications: disabled                         Updater ID: 0.0.0.0
Feature        Mode           Revision
VLAN           Client         0
Pruning             : disabled
VLANs prune eligible: 2-1000
sw02> (enable)
Purple
Awesome, that did it. I was half inclined to do that myself several times this morning, but for some reason I figured that if ""="", then it would match and be happy. But I guess a NULL name is not as good as an actual name. Go figure!
Thanks again glen.
933
