10-27-2006 12:45 PM - edited 03-05-2019 12:29 PM
I had following:
On 2950
int fa0/25
switchport trunk
On 3750
int gi1/0/1
switchport mode trunk
Any help?
10-27-2006 12:49 PM
As long as I remember the 2950 supports only ISL trunks. Try setting the trunk on the 3750 to ISL.
Let me know how it goes,
10-27-2006 12:50 PM
Try to issue the command show interface trunk
Check if the Trunking is ON and what is the encapsulation used on each switch.
10-27-2006 12:54 PM
2950's support dot1q. show log should produce useful information.
10-27-2006 04:31 PM
The 2950's only support dot1q . People seem to like to try and force the trunks on ,myself I prefer to let them negotiate and have never had a problem doing this , try on each side adding "switchport mode dynamic desirable " and this should bring the trunk up . Check your vtp settings , set both as transparent if that is the way you want it and the vtp domain name on each switch "MUST" match exactly for the trunkl to come up .
