07-08-2014 07:10 AM - edited 03-07-2019 07:58 PM
See attached - might make question more clear
we have a layer 2 connection between sites using a local provider for the link. On the remote side is a 3750-X and on the Main Campus side is a 2960. The link is connected via a VLAN. The VLAN interface exists on the Main Campus 5548, core switch
From What I understand, Trustsec cannot be configured on a logical interface but, if we were to configure the logical interfaces as a physical interfaces could we encrypt traffic between the 5548 and the 3750-X?
Even though it would also have to traverse through the 2960 as well?
And traverse the Layer 2 WAN link?
Any other suggestions for accomplishing this?
Thank you, Pat
07-08-2014 01:55 PM
Hi Pat,
Trustsec is supported on SVIs, but I think in order for it to work correctly, you would need to configure it on every device including 5500, 2900, 3750.
See table-1 in this link:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/security/513_n1_1/b_Cisco_n5k_security_config_gd_513_n1_1/b_Cisco_n5k_security_config_gd_513_n1_1_chapter_0111.html
07-09-2014 08:23 AM
Could be mistaken but, I don't believe it is supported on the 2960
07-09-2014 10:03 AM
No, it is not supported on the 2960 series. Also, if you want to encrypt traffic between sites, a better solution is to use IPsec tunnel, but you need a firewall or a router in each location.
It doesn't have to be anything expensive if you don't need a lot of bandwidth.
I use these and they work really well.
have a look:
http://www.amazon.com/Juniper-SSG-5-SB-Security-Services-Gateway/dp/B000IZDN88
07-09-2014 10:38 AM
We do need alot of bandwidth - 800 Mbps. What about 802.1AE?
07-09-2014 11:35 AM
802.1AE is Macsec which is the same as trustsec (I think).
07-09-2014 11:39 AM
Are you sure, you are pushing 800Mb traffic. I don't think the 2960 can handle that much traffic. I would look at your data and figure out how much traffic you are really pushing. What I recommended was 10/100. You can go to a Gig device for a little more money. What is your circuit speed to the provider?
07-09-2014 12:58 PM
The circuit speed is an 800 Mbps Fairpoint link between buildings that are roughly 2 miles apart. We don't usually saturate the link but, 800 Mbps is what we pay for.
07-09-2014 01:28 PM
Understand. Here is another one I use a lot. It costs a little more money, but it comes with 2 1Gig interfaces and 6 10/100. For IPsec, you only need 2 interfaces (one inside and one outside) which you can use the Gig interfaces for..
http://www.cdw.com/shop/products/Juniper-Networks-SRX210-Services-Gateway-High-Memory-Enhanced-security-ap/2426778.aspx
07-09-2014 08:42 AM
Thanks Reza -
Actually just realized that trustsec might not be what I am looking for. I'm looking to encrypt traffic between sites. Is this possible with the present equipment setup?
Thank you
07-09-2014 09:35 AM
Appears I need to configure MACSec between the 5548 and the 3750X. Is this possible?
Thank you
