Trying to purchase a new switch
companyflow
I had two Catalyst 2924-XLs that went down about a week ago due to power problems. I need to purchase two new ones. I cant find any new switches with "SC" fiber connections which is what we have on our fiber cables. Is there a conversion available or are there any current switches that have this connection?
2 Accepted Solutions
Edison Ortiz
Much easier to replace the fiber cables. If you currently have a SC<->SC cable because of the old patch panel, you can purchase a SC<->LC fiber cable which supports your old patch panel while connecting to the new SFP modules that ships with the 2960 model.
HTH,
__
Edison.
Collin Clark
The new switches have SFP ports, which can take fiber or copper connections.
http://www.cisco.com/en/US/docs/routers/7200/install_and_upgrade/gbic_sfp_modules_install/5067g.html
The fiber SFPs have an LC end, so you will need new fiber patch cords or a pig-tail converter.
Hope that helps
Edison Ortiz
HTH,
__
Edison.
Collin Clark
Hope that helps
