09-29-2014 02:51 PM - edited 03-07-2019 08:55 PM
Hey, im trying to route vlan traffic from my 3560 through my 2800 router to my ASA 5520. This Vlan has an IP different from an IP address on a different Vlan. I have two Vlan's setup.
Switch
Vlan 2: 10.1.1.15 /24
Vlan 10: 172.16.10.5 /24
I can route traffic via OSPF through Vlan 2 and hit the internet, but Vlan 10 cant hit the internet.
ASA Config:
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address 192.168.1.103 255.255.255.0
interface GigabitEthernet0/1
nameif inside
security-level 100
ip address 10.1.1.30 255.255.255.0
interface GigabitEthernet0/1.10
vlan 10
nameif vlan10
security-level 0
ip address 172.16.10.10 255.255.255.0
interface GigabitEthernet0/2
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
no nameif
no security-level
no ip address
interface Management0/0
no nameif
no security-level
no ip address
ftp mode passive
access-list inside extended permit ip any any
access-list vlan10 extended permit ip any any
pager lines 24
mtu outside 1500
mtu inside 1500
mtu vlan10 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
nat (vlan10) 1 0.0.0.0 0.0.0.0
access-group inside in interface inside
access-group vlan10 in interface vlan10
router ospf 1
network 10.1.1.0 255.255.255.0 area 0
network 172.16.10.0 255.255.255.0 area 0
network 192.168.1.0 255.255.255.0 area 0
log-adj-changes
default-information originate always
route outside 0.0.0.0 0.0.0.0 192.168.1.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh 10.1.1.0 255.255.255.0 inside
ssh timeout 5
console timeout 0
dhcpd address 10.1.1.31-10.1.1.99 inside
dhcpd dns 8.8.8.8 interface inside
dhcpd enable inside
dhcpd address 172.16.10.21-172.16.10.50 vlan10
dhcpd dns 8.8.8.8 interface vlan10
dhcpd enable vlan10
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
service-policy global_policy global
prompt hostname context
Cryptochecksum:dcdbe42707254b43aa47e147b0c6598a
ciscoasa#
Switch config:
aaa new-model
aaa session-id common
system mtu routing 1500
vtp mode transparent
ip routing
ip domain-name
crypto pki trustpoint TP-Self-signed
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate
revocation-check none
rsakeypair TP-self-signed
crypto pki trustpoint TP-self-signed-1338394240
revocation-check crl
spanning-tree mode pvst
no spanning-tree vlan 2
vlan internal allocation policy ascending
vlan 2,10,221
interface Loopback0
ip address 20.20.20.20 255.255.255.0
interface FastEthernet0/1
switchport access vlan 2
ip access-group Digi in
spanning-tree bpduguard disable
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
switchport access vlan 10
switchport mode access
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
switchport access vlan 7
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface Vlan1
no ip address
shutdown
interface Vlan2
description Network Management VLAN
ip address 10.1.1.15 255.255.255.0
interface Vlan7
no ip address
interface Vlan10
ip address 172.16.10.5 255.255.255.0
router ospf 1
log-adjacency-changes
redistribute connected subnets
network 10.1.1.0 0.0.0.255 area 0
network 172.16.10.0 0.0.255.255 area 0
ip classless
ip route profile
ip route 0.0.0.0 0.0.0.0 10.1.1.20
ip http server
ip http secure-server
ip radius source-interface Vlan7
radius-server host 172.x.x.x auth-port 1645 acct-port 1646
radius-server key 7 142402041E102F282C796166
banner login ^C
# WARNING #
# This network device is private property of #
# Unauthorized access is strictly prohibited and #
# subject to prosecution under international, state, federal #
# and local statutes. This device is subject to monitoring. #
# If you are unauthorized or do not consent to #
# monitoring of usage disconnect NOW. #
######################################################################^C
end
GA-Test-Switch-3560#
Router config:
hostname Router
boot-start-marker
boot-end-marker
no logging console
enable secret 5 $
no network-clock-participate wic 0
no network-clock-participate wic 1
aaa new-model
aaa authentication login default local
ip subnet-zero
ip cef
no ftp-server write-enable
voice-card 0
no dspfarm
username
controller E1 0/0/0
controller E1 0/1/0
interface Loopback0
ip address 10.10.10.10 255.255.255.0
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
ip address 10.1.1.20 255.255.255.0
duplex auto
speed auto
router ospf 1
network 192.168.1.0 0.0.0.255 area 0
ip classless
ip http server
no ip http secure-server
ip ospf name-lookup
control-plane
line con 0
line aux 0
line vty 0 4
scheduler allocate 20000 1000
end
Router#
Help me please.
Solved! Go to Solution.
10-01-2014 03:01 PM
Hello Vince ,
These seems to be current configs . May be i did not made myself clear enough.
As you say that you tried both of the suggested options for multiple vlan setup and they did not work for you , I asked for those configuration on both end in both scenarios ( which did not worked for you ) .
Because at least in case of connecting switch ( trunk ) to ASA subinterfaces it should have worked .
Sunil Bhadauria
10-01-2014 03:37 PM
I removed the config because it hadnt worked. This is what I did...I basically matched fa0/21 to fa0/22 with the exception of vlan 20 rather than vlan 10. I even tried using fa0/22 to trunk the router where I had setup a sub-interface pointing to vlan 20. With that setup I was able to ping to the router using the vlan 20 ip I had setup. I did the same thing to the ASA using a sub-interface pointing to vlan 20. I couldnt ping the ASA with that address. I tried different scenarios, but none worked except for making fa0/21 a switchport on vlan 20. The reason fa0/21 is on vlan 10 is because it works to my ASA and im able to pull DHCP and get to the internet.
interface Vlan20
ip address 172.16.20.10 255.255.255.0
switchport trunk native vlan 100
switchport trunk allowed vlan 10,20
switchport mode trunk
spanning-tree portfast
10-02-2014 10:28 AM
Once again I want to thank everyone for their help. After re-reading all the posts I realized what I was doing wrong. I was going at it the wrong way. I created two trunk ports on my switch and they both connect to my router and ASA. I then created two sub-interfaces on my router and ASA to coincide with the Vlans I created on my switch. I can ping all the way through with each IP assigned to interfaces and sub-interfaces. I was still racking my brain as to why I couldnt ping with the main IP's I assigned to each device. I then realized like an idiot I forgot to connect both devices to my switch through a regular port with access to the main Vlan on my switch. D'OH. I assigned a different vlan to each switch port and I can plug my laptop into each one and pull DHCP and get to the internet. Im also doing all my routing through OSPF. What a relief. Thanks again guys!
09-29-2014 06:45 PM
A physical and logical topology diagram would help to understand the setup.
Akash
09-30-2014 02:57 PM
Hello Vince ,
I have some experience with firewalls so will try to answer the query
Here are two things that I can see , could be worth checking :
1)
Wan side port has security level as 0 , lowest
For Gi0/1 interface ( vlan 2 is connected and reaching internet via this port ) has security-level as 100 , highest . We do not need any policy to reachability from higher to lower security zones in ASA .
But for sub-interface Gi0/1.10 ( Vlan 10 is connected and reaching internet via this port ) i can see security-level as 0 , lowest .
And as far as I know , By default interfaces on the same security level cannot communicate with each other .
anyways if needed below command can achieve it :
same-security-traffic permit inter-interface
2) another point is why on ASA we have configured vlan 2 ip on physical interface and Vlan 10 ip on sub-interface . I never tested such configuration and was exptecting to see another subinterface for vlan 2 connectivity as well .
Hope to help .
Sunil Bhadauria
! kindly rate all helpful posts !
09-30-2014 08:39 PM
I diagram would be very helpful to get this resolved for you.
09-30-2014 08:44 PM
Also on the switch I don't see any ports that are setup to be trunks.
How I've done this in the past is to setup a trunk, set it with a native VLAN that isn't in use anywhere (3100), and then create sub-interfaces for any and all VLANs that need to be tagged to the ASA. This then allows you to also tag VLAN 1 traffic and keep a uniformed configuration.
