Trying to route Vlan traffic from 3560 through ASA 5520
Hey, im trying to route vlan traffic from my 3560 through my 2800 router to my ASA 5520. This Vlan has an IP different from an IP address on a different Vlan. I have two Vlan's setup.
Switch
Vlan 2: 10.1.1.15 /24
Vlan 10: 172.16.10.5 /24
I can route traffic via OSPF through Vlan 2 and hit the internet, but Vlan 10 cant hit the internet.
ASA Config:
interface GigabitEthernet0/0
 nameif outside
 security-level 0
 ip address 192.168.1.103 255.255.255.0
interface GigabitEthernet0/1
 nameif inside
 security-level 100
 ip address 10.1.1.30 255.255.255.0
interface GigabitEthernet0/1.10
 vlan 10
 nameif vlan10
 security-level 0
 ip address 172.16.10.10 255.255.255.0
interface GigabitEthernet0/2
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/3
 no nameif
 no security-level
 no ip address
interface Management0/0
 no nameif
 no security-level
 no ip address
ftp mode passive
access-list inside extended permit ip any any
access-list vlan10 extended permit ip any any
pager lines 24
mtu outside 1500
mtu inside 1500
mtu vlan10 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
nat (vlan10) 1 0.0.0.0 0.0.0.0
access-group inside in interface inside
access-group vlan10 in interface vlan10
router ospf 1
 network 10.1.1.0 255.255.255.0 area 0
 network 172.16.10.0 255.255.255.0 area 0
 network 192.168.1.0 255.255.255.0 area 0
 log-adj-changes
 default-information originate always
route outside 0.0.0.0 0.0.0.0 192.168.1.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh 10.1.1.0 255.255.255.0 inside
ssh timeout 5
console timeout 0
dhcpd address 10.1.1.31-10.1.1.99 inside
dhcpd dns 8.8.8.8 interface inside
dhcpd enable inside
dhcpd address 172.16.10.21-172.16.10.50 vlan10
dhcpd dns 8.8.8.8 interface vlan10
dhcpd enable vlan10
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
Cryptochecksum:dcdbe42707254b43aa47e147b0c6598a
ciscoasa#
Switch config:
aaa new-model
aaa session-id common
system mtu routing 1500
vtp mode transparent
ip routing
ip domain-name
crypto pki trustpoint TP-Self-signed
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate
 revocation-check none
 rsakeypair TP-self-signed
crypto pki trustpoint TP-self-signed-1338394240
 revocation-check crl
spanning-tree mode pvst
no spanning-tree vlan 2
vlan internal allocation policy ascending
vlan 2,10,221
interface Loopback0
 ip address 20.20.20.20 255.255.255.0
interface FastEthernet0/1
 switchport access vlan 2
 ip access-group Digi in
 spanning-tree bpduguard disable
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
 switchport access vlan 10
 switchport mode access
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
 switchport access vlan 7
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface Vlan1
 no ip address
 shutdown
interface Vlan2
 description Network Management VLAN
  ip address 10.1.1.15 255.255.255.0
interface Vlan7
 no ip address
interface Vlan10
 ip address 172.16.10.5 255.255.255.0
router ospf 1
 log-adjacency-changes
 redistribute connected subnets
 network 10.1.1.0 0.0.0.255 area 0
 network 172.16.10.0 0.0.255.255 area 0
ip classless
ip route profile
ip route 0.0.0.0 0.0.0.0 10.1.1.20
ip http server
ip http secure-server
ip radius source-interface Vlan7
radius-server host 172.x.x.x auth-port 1645 acct-port 1646
radius-server key 7 142402041E102F282C796166
banner login ^C
#                               WARNING                              #
#    This network device is private property of                      #
#    Unauthorized access is strictly prohibited and                  #
#    subject to prosecution under international, state, federal      #
#    and local statutes. This device is subject to monitoring.       #
#    If you are unauthorized or do not consent to                    #
#    monitoring of usage disconnect NOW.                             #
######################################################################^C
end
GA-Test-Switch-3560#
Router config:
hostname Router
boot-start-marker
boot-end-marker
no logging console
enable secret 5 $
no network-clock-participate wic 0
no network-clock-participate wic 1
aaa new-model
aaa authentication login default local
ip subnet-zero
ip cef
no ftp-server write-enable
voice-card 0
 no dspfarm
username
controller E1 0/0/0
controller E1 0/1/0
interface Loopback0
 ip address 10.10.10.10 255.255.255.0
interface FastEthernet0/0
 no ip address
 shutdown
 duplex auto
 speed auto
 ip address 10.1.1.20 255.255.255.0
 duplex auto
 speed auto
router ospf 1
 network 192.168.1.0 0.0.0.255 area 0
ip classless
ip http server
no ip http secure-server
ip ospf name-lookup
control-plane
line con 0
line aux 0
line vty 0 4
scheduler allocate 20000 1000
end
Router#
Help me please.
2 ACCEPTED SOLUTIONS
Hello Vince ,
Hello Vince ,
I have some experience with firewalls so will try to answer the query
Here are two things that I can see , could be worth checking :
1)
Wan side port has security level as 0 , lowest
For Gi0/1 interface ( vlan 2 is connected and reaching internet via this port ) has security-level as 100 , highest . We do not need any policy to reachability from higher to lower security zones in ASA .
But for sub-interface Gi0/1.10 ( Vlan 10 is connected and reaching internet via this port ) i can see security-level as 0 , lowest .
And as far as I know , By default interfaces on the same security level cannot communicate with each other .
anyways if needed below command can achieve it :
same-security-traffic permit inter-interface
2) another point is why on ASA we have configured vlan 2 ip on physical interface and Vlan 10 ip on sub-interface . I never tested such configuration and was exptecting to see another subinterface for vlan 2 connectivity as well .
Hope to help .
Sunil Bhadauria
! kindly rate all helpful posts !
Also on the switch I don't
Also on the switch I don't see any ports that are setup to be trunks.
How I've done this in the past is to setup a trunk, set it with a native VLAN that isn't in use anywhere (3100), and then create sub-interfaces for any and all VLANs that need to be tagged to the ASA. This then allows you to also tag VLAN 1 traffic and keep a uniformed configuration.
Hey,How does router knows
Hey,
How does router knows about 172.x.x.x subnet?
RS.
I would assume through ospf,
I would assume through ospf, but I could be wrong. Do I need to make a sub interface with the 172.16.x.x subnet on the router?
Indeed. Try that out and let
Indeed. Try that out and let us know the result.
HTH.
RS.
Didn't work. I created a sub
Didn't work. I created a sub interface on the router pointing to 172.16.10.x and still nothing. Im doing this in a lab environment using a 4G LTE connection for internet. I can switch Vlan's on the switch port that my laptop is connected to and get out to the internet. What else am I missing?
Do you have vlan 10 passing
Do you have vlan 10 passing between switch and router?
I hope you are connecting your machine on switch with access vlan 10. Check with command:
#show int trunk
And make sure that vlan 10 is passing from switch to router.
RS.
It should have vlan 10
It should have vlan 10 passing through. I setup the vlan the same way as vlan 2 with the exception of the sub interface on the router. Not too mention the ospf statements on the switch, router and asa. On the router it sees the vlan 10 ip as ospf. Same for the asa.
Still I suggest running '
Still I suggest running '#show int trunk' command on switch verify; because there could be a possibility of broken broadcast domain.
RS.
I would like to thank all of
I would like to thank all of you that helped me. I finally got it working. At one point I figured by creating a sub-interface with Vlan 10 under the main interface with Vlan 2 would work just fine and pass traffic through to my ASA. Boy was I wrong. I ended up removing the sub-interface and created a new interface under G0/2 pointing to Vlan 10. I then trunked the router port over to my switch as was suggested. On my ASA I added the typical access-lists to get it through. OSPF passes traffic through just fine. Thank you all again. If anyone wants to check out my configs i'll be more than happy to share. Now I have a 7200 VXR router to play with and add to my lab network.
I do have one more question though...In my network I have a switch, ASA and router. Whats the best practice to set it up? Internet-ASA-Router-Switch or Internet-Router-ASA-Switch?
Also, what if I want to add another Vlan with a different IP? How would I go about setting that up if I run out of ports on my router and ASA?
Hello Vince , Its good to
Hello Vince ,
Its good to hear that issue is resolved .
Regarding current concern , I would recommend to have ASA interfacing with internet . As we never know what is coming from internet side and may cause resource issues on devices , ASA are built to avoid such issues .
Sunil Bhadauria
Not sure my edit came through
Not sure my edit came through, but
Hello Vince , I that case you
Hello Vince ,
I that case you may use sub-interfaces on asa and connect this interface to a trunk port ( dot1q).Physical port on ASA act as trunk port and we do not need to configure it separately .
Another solution I can think of is :
however i have never tried but i think it will work , you can try connect this asa port to a router port which can have multiple tagged sub-interfaces ( dot1q).
Sunil Bhadauria
! Kindly rate all helpful posts and accordingly make correct to help forum !
I tried that earlier and it
I tried that earlier and it did what I wanted, but it takes away from the ports on the router and switch. On the router im already using both ports to the switch. Would I create a sub-interface on the router under fa0/2? Like fa0/2.xx? I tried that as well and it didnt work. Unless I was missing something. I dunno. I also tried sub-interfaces on the ASA and trunked them to the switch and I do get the trunking back and forth, but it didnt work.
May be you can provide the
May be you can provide the configurations of either side in both scenarios .
Sunil Bhadauria
Here's the config for both my
Here's the config for both my router and ASA as they stand right now. If you need the switch config let me know...
Router#sh config
Using 1258 out of 245752 bytes
version 12.3
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
no logging console
enable secret 5 $1$AjKR$u/X0XfG77hUeiQ5XLMxQp0
aaa new-model
ip subnet-zero
ip cef
voice-card 0
 no dspfarm
username
controller E1 0/0/0
controller E1 0/1/0
interface Loopback0
 duplex auto
 speed auto
 ip address 172.16.10.11 255.255.255.0
 duplex auto
 speed auto
router ospf 1
 network 172.16.10.0 0.0.0.255 area 0
 network 172.16.20.0 0.0.0.255 area 0
ip classless
ip http server
ip ospf name-lookup
control-plane
line con 0
line aux 0
line vty 0 4
end
Router#
ciscoasa# sh config
: Saved
: Written by enable_15 at 15:58:15.319 UTC Wed Oct 1 2014
ASA Version 8.0(4)
hostname ciscoasa
enable
names
 nameif outside
 security-level 0
 nameif inside
 security-level 100
 nameif vlan10
 security-level 100
 ip address 172.16.10.12 255.255.255.0
 no nameif
 no security-level
 no ip address
 no nameif
 no security-level
 no ip address
ftp mode passive
pager lines 24
mtu outside 1500
mtu inside 1500
mtu vlan10 1500
no failover
asdm image disk0:/asdm-524.bin
arp timeout 14400
router ospf 1
 network 172.16.20.0 255.255.255.0 area 0
 log-adj-changes
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 10.1.1.41-10.1.1.99 inside
dhcpd enable inside
dhcpd address 172.16.10.50-172.16.10.99 vlan10
dhcpd enable vlan10
username
 parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
Cryptochecksum:cd91a5c7189be1f5227d10cf9b38de80
ciscoasa#
Hello Vince , These seems to
Hello Vince ,
These seems to be current configs . May be i did not made myself clear enough.
As you say that you tried both of the suggested options for multiple vlan setup and they did not work for you , I asked for those configuration on both end in both scenarios ( which did not worked for you ) .
Because at least in case of connecting switch ( trunk ) to ASA subinterfaces it should have worked .
Sunil Bhadauria
I removed the config because
I removed the config because it hadnt worked. This is what I did...I basically matched fa0/21 to fa0/22 with the exception of vlan 20 rather than vlan 10. I even tried using fa0/22 to trunk the router where I had setup a sub-interface pointing to vlan 20. With that setup I was able to ping to the router using the vlan 20 ip I had setup. I did the same thing to the ASA using a sub-interface pointing to vlan 20. I couldnt ping the ASA with that address. I tried different scenarios, but none worked except for making fa0/21 a switchport on vlan 20. The reason fa0/21 is on vlan 10 is because it works to my ASA and im able to pull DHCP and get to the internet.
interface Vlan20
 ip address 172.16.20.10 255.255.255.0
 switchport trunk native vlan 100
 switchport trunk allowed vlan 10,20
 switchport mode trunk
 spanning-tree portfast
Once again I want to thank
Once again I want to thank everyone for their help. After re-reading all the posts I realized what I was doing wrong. I was going at it the wrong way. I created two trunk ports on my switch and they both connect to my router and ASA. I then created two sub-interfaces on my router and ASA to coincide with the Vlans I created on my switch. I can ping all the way through with each IP assigned to interfaces and sub-interfaces. I was still racking my brain as to why I couldnt ping with the main IP's I assigned to each device. I then realized like an idiot I forgot to connect both devices to my switch through a regular port with access to the main Vlan on my switch. D'OH. I assigned a different vlan to each switch port and I can plug my laptop into each one and pull DHCP and get to the internet. Im also doing all my routing through OSPF. What a relief. Thanks again guys!
 A physical and logical
A physical and logical topology diagram would help to understand the setup.
Akash
Hello Vince ,
Hello Vince ,
1)
Hope to help .
Sunil Bhadauria
I diagram would be very
I diagram would be very helpful to get this resolved for you.
686
