02-12-2008 12:50 PM - edited 03-05-2019 09:06 PM
how bad is this?
A#sh processes cpu
CPU utilization for five seconds: 93%/36%; one minute: 90%; five minutes: 88
Im trying to uderstand the 90% and what they mean overall
02-12-2008 01:03 PM
The 90 is the CPU utilization over the last 60 seconds. It looks like your router is using a lot of CPU cycles. Post the results of the following and maybe we can help.
show version
show proc cpu | excl 0.00%__0.00%__0.00%__
02-12-2008 01:09 PM
Hi Richard,
one minute: 90% means the average cpu utilization over a 1 minute period.
The same applies to the five minutes:88% - cpu utilization over a 5 minute period.
These values are very high. Your box is working close to its limits.
Users can experience higher latency and more packet drops when this is happening.
You should look into what traffic is causing this.
Cheers:
Istvan
02-12-2008 01:18 PM
A#show proc cpu | excl 0.00%__0.00%__0.00%_
CPU utilization for five seconds: 47%/19%; one minute: 46%; five minutes: 47%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
4 1972144 394023 5005 0.00% 0.04% 0.05% 0 Check heaps
9 5048956 9633965 524 0.15% 0.14% 0.14% 0 ARP Input
33 1602612 59429 26966 0.55% 0.06% 0.00% 0 Per-minute Jobs
44 9032701881577385170 572 26.00% 28.05% 28.88% 0 IP Input
82 172 191 900 1.11% 0.16% 0.03% 66 Virtual Exec
this is the latest..
what is the comfort zone..60%?
02-12-2008 01:20 PM
How about a show version too?
02-12-2008 01:38 PM
A#sh ver
IOS (tm) C2600 Software (C2600-IPBASE-M), Version 12.3(6c), RELEASE SOFTWARE (fc
1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Tue 20-Jul-04 05:24 by kellythw
Image text-base: 0x80008098, data-base: 0x80ED06CC
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
A uptime is 5 weeks, 5 days, 13 hours, 45 minutes
System returned to ROM by reload at 02:49:49 UTC Thu Jan 3 2008
System restarted at 02:51:48 UTC Thu Jan 3 2008
System image file is "flash:c2600-ipbase-mz.123-6c.bin"
cisco 2621XM (MPC860P) processor (revision 0x301) with 126976K/4096K bytes of me
mory.
Processor board ID JAE08255X1W (1978396964)
M860 processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
02-12-2008 01:42 PM
Here's a good troubleshooting guide.
http://cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a00800a70f2.shtml
What's changed in your network? How long has this router been experiencing high CPU util? What interfaces are in use? How are you processing packets?
02-12-2008 03:51 PM
More of a concern is your high software process rate, which appears to be in IP input.
See http://cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00801c2af3.shtml
02-12-2008 06:46 PM
thx!...I just happend to issue the sho process cpu command and noticed the utilization..
I was playing with PRTG and was wondering
if it was causing a heavy load on the cpu and
i discovered this
