05-14-2007 05:27 AM - edited 03-05-2019 04:03 PM
I am trying to use the ttcp and chargen commands but I keep getting connection refused by remote host. I have 2 switches with very minimal configs on them. I can telnet from switch A to switch B but when I try to use switch A to chargen or ttcp to B, B is refusing the connection.
05-14-2007 06:14 AM
Did you configure "service tcp-small-servers" ?
This feature is disabled by default on Cisco IOS Software Versions 11.3 and later.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
05-14-2007 06:16 AM
For ttcp you need to start the program in receive mode on the receiving station. Note that ttcp might not be available on all devices and is not officially supported.
Hope this helps,
