TTL
Hi Netpro
When I ping a PC I get TTL=54
when I ping a Router I get TTL=249
when I ping a HP server I get TTL=110
why TTL changes
1 REPLY
Hall of Fame Super Silver
Re: TTL
Pratik
When you generate the ping packet your end station specifies the TTL of the packet. When the other device generates the ping response it specifies the TTL of the response packet. It is likely that a PC, or a Router, or an HP server might specify different TTL values. So depending of what the remote device specifies as the TTL, and depending on how far away they are (how many hops are decremented in the TTL) it is reasonable that you would get different results in your ping.
Rick
107
