09-20-2013 08:44 AM - edited 03-07-2019 03:35 PM
Could you please tel me how i can use a loop back with a tunnel GRE ?
Thanks you.
09-20-2013 08:52 AM
Are you wanting to use it as source/destination for the tunnel termination, or are you just wanting to advertise the loopback over the tunnel?
HTH,
John
*** Please rate all useful posts ***
09-20-2013 08:58 AM
hi John,
is to put in a next hop for route map,therefore, source / destination, is not it?
James,
09-20-2013 10:00 AM
You can apply a next-hop to a tunnel interface. For example if you have 2 ends of a tunnel:
192.168.1.1 - side A
192.168.1.2 - side B
Your route-map on side A can set a next-hop to 192.168.1.2 to force traffic over the tunnel if needed....
HTH,
John
09-20-2013 10:28 AM
That is doesn't working,i wat just how set up a lookback whith a tunnel GRE plz,
