two 2911 routers and 3560 switches (load balancing and redundancy)
Good day, Sir !
I have a model with hierarchical model. Two routers 2911 and two core switches 3560, two providers.
I want to design redundancy scheme. Can you advice me how is better to do it ? here you can find image with topology, can you say is it good idea to connect with devices in this way ?
Hope on you help ! Thank you !!!
1 REPLY
Hi,If you want to configure
If you want to configure redundancy in your network on LAN you can use HSRP and from the WAN side depending on the connection with the provider you can either use BGP or any IGP.
If you want to have load balancing as well with redundancy you can define differnt  HSRP group for different  vlan and on the wan with BGP you can use multipath option or with IGP you can manipulate the route matric.
Thanks & Regards
Sandeep
88
