05-22-2007 01:32 AM - edited 03-05-2019 04:12 PM
Is it possible to configure two default routes with the same metric on a cisco switch 3750?
In fact, I would like to make load balancing between 2 firewalls with these two routes.
Thanks you by advance for your help!
Solved! Go to Solution.
05-22-2007 04:28 AM
You can point your two default static routes to your next hope gateway
ip route 0.0.0.0 0.0.0.0 x.x.x.x
ip route 0.0.0.0 0.0.0.0 y.y.y.y
Bydefault the switch will add both the routes to its routing table with two gateways listed.By default L3 switches/router will do per-destination load-balancing if it has multiple routes avialable for a destination.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094820.shtml
HTH,Please rate if it does.
-amit singh
05-22-2007 01:35 AM
Hi Friend,
Yes that's possible.
Ankur
05-22-2007 04:11 AM
Hi Ankur,
Could u plz explain how it works ?
05-22-2007 04:28 AM
-amit singh
05-23-2007 01:26 AM
Hi all,
Thanks you all for your help!
Bye.
