Two Host on the same subnet connected to two Cisco routers
mactej6228
Please refer on the attached file. PING is unsuccesful for both pc. What routing protocol that I'm going to use here? I tried RIPv2 but I still a "Request timed out" message.  -- The concept of this topology will be used in a larger network setup.. Please help..
R1(RIP)
network: 192.168.0.0 & 10.0.0.0
R2 (RIP)
Giuseppe Larosa
Hello Mark,
what you are looking for is an OSI Layer 2 transport service over an IP routed network.
No routing protocol can give you this.
L2TPv3 can be useful in these cases but you have to be aware that all broadcast, multicast and unknown unicast traffic will be carried over the WAN consuming bandwidth
see
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t2/feature/guide/gtl2tpv3.html
it is supported on ISR routers like C3725 or C2800 with appropriate feature set.
A routed solution with different IP subnets at the two sites should be preferred if possible.
Hope to help
Giuseppe
Can you change the end networks to make them different subnets?
It won't work because they use the same subnet on two different locations.
Change one of the networks to 192.168.1.0/24 or something similar.
Giuseppe Larosa
Hello Mark,
see
Hope to help
Giuseppe
Thanks for all your replies it give me some insights...
