03-18-2014 09:11 AM - edited 03-07-2019 06:45 PM
I have a router on a stick running two vlans. How would I configure vlan routing so that both vlans can access the same host on one of the vlans?
Solved! Go to Solution.
03-18-2014 11:23 AM
It is partly to do with routing between vlans because you need access to resources on one vlan from others. But it is also internet by the looks of it.
So, concentrating on vlan 11 it's default gateway has to be the router subinterface IP for vlan 11 which you have done.
What i mean by adding routes is that the gateway device does not know anything about the vlan 11 subnet. So assuming it is a Cisco router you would need to add to the gateway device -
ip route 122.98.11.0 255.255.255.0 122.98.12.254
and you would need a route for all not vlan 12 subnets pointing to the same next hop IP as above.
This would mean the gateway device now knows where to send return traffic to for non vlan 12 subnets.
In terms of vlan 12 clients please see my previous post as to which defautl gateway you can use.
Jon
03-18-2014 09:16 AM
Not sure i follow ie. if you have routing on a stick setup then it should work anyway ie. nothing to do.
So for clients in the vlan that also has the host there is no routing to be done ie. it is all L2 switched.
For the other vlan yes you need L3 between the vlans for it to work.
So is your setup not working ?
Jon
03-18-2014 09:20 AM
I am not sure how to setup the L3 routing part.
VLAN 11 122.98.11.0 255.255.255.0
VLAN 12 122.98.12.0 255.255.255.0
I need vlan 11 to be able to access 122.98.12.250 (vlan 12).
I have tried setting up access lists on the router (3745) but these have not worked.
03-18-2014 09:38 AM
I think we may be talking at cross purposes here.
Is the question based on the fact that you had the routing working but now you want to use acls to restrict the traffic and with the acls it isn't.
Or is the question you never got the routing working in the first place.
Jon
03-18-2014 09:42 AM
The routing was never working.
03-18-2014 09:49 AM
Okay, so what do your configs look like ?
In summary you need to -
1) make sure both vlans have been created on the switch ie. "sh vlan brief"
2) on the switch configure the connection to the router interface to be a trunk link allowing both vlans
3) on the router configure subinterfaces for each vlan using the encapsulation command together with an IP address
4) on the clients assign an IP from the relevant subnet and set the default gateway to be the corresponding router subinterface IP
5) assign the ports on the switch to be in the correct vlan(s) for the clients
If you cannot ping between clients in different vlans then try pinging from a client in one of the vlans to the router subinterface for the other vlan.
If this works make sure you do not have firewalls running on the clients that would block the ICMP requests.
Jon
03-18-2014 09:57 AM
I can ping within a vlan, but not between two vlans. Here is my router's running config:
version 12.4
service password-encryption
hostname 3745_Router
boot-start-marker
boot-end-marker
enable secret 5 $1$dJG3$bJtVXeeesSHeu6PjIJfu60
no aaa new-model
clock timezone EST -5
clock summer-time DST recurring
no network-clock-participate slot 2
voice-card 2
dspfarm
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 122.98.12.1 122.98.12.99
ip dhcp excluded-address 122.98.12.200 122.98.12.254
ip dhcp pool VoIP
network 192.168.100.0 255.255.255.0
dns-server 192.168.100.254
default-router 192.168.100.254
option 150 ip 192.168.100.254
ip dhcp pool admin
network 122.98.12.0 255.255.255.0
dns-server 122.98.12.250
default-router 122.98.12.250
ip dhcp pool guest
network 122.98.10.0 255.255.255.0
ip dhcp pool shop
network 122.98.11.0 255.255.255.0
ip dhcp pool default
network 122.98.1.0 255.255.255.0
controller T1 2/0
framing sf
linecode ami
interface Loopback1
ip address 122.98.0.1 255.255.255.0
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 122.98.1.254 255.255.255.0
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 122.98.10.254 255.255.255.0
interface FastEthernet0/0.11
encapsulation dot1Q 11
ip address 122.98.11.254 255.255.255.0
ip access-group gateway2 in
ip access-group gateway2 out
interface FastEthernet0/0.12
description Management Gateway
encapsulation dot1Q 12
ip address 122.98.12.254 255.255.255.0
interface FastEthernet0/0.13
encapsulation dot1Q 13
ip address 122.98.13.254 255.255.255.0
interface Serial0/0
no ip address
shutdown
clock rate 2000000
interface FastEthernet0/1
ip address 192.168.1.254 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1.100
description VoIP Gateway
encapsulation dot1Q 100
ip address 192.168.100.254 255.255.255.0
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface Serial1/0
no ip address
shutdown
serial restart-delay 0
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 122.98.12.250
ip route 122.98.11.0 255.255.255.0 122.98.12.250
ip http server
ip http secure-server
ip http path flash:/new
ip access-list standard gate
permit 122.98.12.250
ip access-list standard gateway
ip access-list extended gateway2
permit tcp any host 122.98.12.250
permit ip any any
deny ip any 0.0.0.0 255.255.255.0
tftp-server flash:/phone/7940-7960/P00308010200.bin alias P00308010200.bin
tftp-server flash:/phone/7940-7960/P00308010200.loads alias P00308010200.loads
tftp-server flash:/phone/7940-7960/P00308010200.sb2 alias P00308010200.sb2
tftp-server flash:/phone/7940-7960/P00308010200.sbn alias P00308010200.sbn
tftp-server flash:/phone/7912/cmterm-7912-8.0.3-sccp alias cmterm-7912-8.0.3-sccp
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
control-plane
voice-port 4/0/0
description FSX Port 4/0/0
station-id name FXS Port 4/0/0
station-id number 2001
caller-id enable
voice-port 4/0/1
description FSX Port 4/0/1
station-id name FXS Port 4/0/1
station-id number 2002
caller-id enable
voice-port 4/1/0
connection plar opx 5000
voice-port 4/1/1
dial-peer voice 2001 pots
destination-pattern 2001
port 4/0/0
dial-peer voice 2002 pots
destination-pattern 2002
port 4/0/1
dial-peer voice 2 pots
destination-pattern [2-9].........
port 4/1/0
forward-digits all
dial-peer voice 3 pots
destination-pattern 1[2-9].........
port 4/1/0
forward-digits all
dial-peer voice 999020 pots
service h.323
port 4/1/0
telephony-service
load 7960-7940 P00308010200
load 7912 cmterm-7912-8.0.3-sccp
max-ephones 10
max-dn 100
ip source-address 192.168.100.254 port 2000
auto assign 1 to 10
system message Anderson VoIP Network
time-zone 13
voicemail 2002
max-conferences 8 gain -6
moh flash:/mohw.au
web admin system name jake secret 5 $1$lSG/$erZUKe/c/uoNeu.TnvRLG0
dn-webedit
time-webedit
transfer-system full-consult
directory entry 1 1001 name Basement
create cnf-files version-stamp 7960 Apr 23 2013 20:18:58
ephone-dn 1
number 1001 secondary 800
label 1001
description 1001
name Basement
call-forward busy 2002
call-forward noan 2002 timeout 5
ephone-dn 2
number 1002
label 1002
description 1002
name Jake
call-forward noan 2002 timeout 20
ephone-dn 3
number 1003
label 1003
description 1003
name 1003
ephone-dn 4
number 1004
label 1004
description 1004
name 1004
ephone-dn 5
number 1005
label 1005
description 1005
name 1005
ephone-dn 6
number 1006
label 1006
description 1006
name 1006
ephone-dn 7
number 1007
label 1007
description 1007
name 1007
ephone-dn 8
number 1008
label 1008
description 1008
name 1008
ephone-dn 9
number 1009
label 1009
description 1009
name 1009
ephone-dn 10
number 1010
label 1010
description 1010
name 1010
ephone-dn 100
number 5000
ephone 1
device-security-mode none
mac-address 0014.1CCE.24D3
type 7940
button 1:1 2:100
ephone 2
mac-address 000A.F408.90B7
type 7940
button 1:2 2:100
line con 0
logging synchronous
line aux 0
line vty 0 4
password 7 060506324F41
logging synchronous
login
end
03-18-2014 10:04 AM
Can you be more specific ie. pick two vlans that you cannot ping between and we can work on those.
Can you from a client in one vlan ping the router subinterfaces for other vlans ?
Jon
03-18-2014 10:08 AM
Im working on vlans 11 and 12.
From vlan 11 I can ping the vlan 12 sub interface.
From vlan 12 I can't ping the vlan 11 sub interface.
03-18-2014 10:21 AM
Your DHCP pools are handing out the wrong default gateways ie.
both vlan 11 and vlan 12 are setting the default gateway to be 122.98.12.250 as are most of the other pools. the default gateway should be the corresponding router subinterface IP for each pool.
Also the acl is doing nothing so you may as well remove it.
Jon
03-18-2014 10:23 AM
How would I then route the router to the gateway so:
client --------> router ----------> gateway
03-18-2014 10:30 AM
I don't know what the "gateway" is but you have these static routes -
the first route is a default route to send all traffic to that next hop IP which is presumably the gateway.
The second route i have no idea what it is meant to do as you are routing that subnet on the router with a subinterface.
Jon
03-18-2014 10:36 AM
the gateway is 122.98.12.250, however if I set the client default gateway to the router sub interface, I can not ping the gateway or access the internet.
03-18-2014 10:47 AM
The gateway device will need to have routes for all the non vlan 12 subnets pointing back to 122.98.12.254 otherwise it doesn't know how to get to them.
You can't just set the default gateway for all vlans to be 122.98.12.250 because they don't know how to reach that. So for all non vlan 12 subnets you need to modify your DHCP pools and change the default gateways.
For vlan 12 if you leave the default gateway as the 122.98.12.250 address then that means all inter vlan traffic to and from vlan 12 has to go to the gateway device and then back to the router with the subinterfaces on it.
If you change the vlan 12 default gateway to be the router subinterface then all inter vlan traffic goes via that router but vlan 12 internet traffic goes to that router and back out to the internet gateway device.
Ideally you want the gateway device on a separate subnet ie. not one of the vlan subnets. Then all vlans have their default gateways set to the router subinterfaces and internet traffic is simply routed via that router to the internet gateway device on a separate subnet.
Jon
03-18-2014 10:56 AM
I have changed the default gateway to the sub interface, however I still can not access the internet.
