08-31-2012 03:24 PM - edited 03-07-2019 08:38 AM
Afternoon all,
I've several production Catalyst switches that are listening on the same IPv4 and IPv6 ports. The problem is I don't want the switches listening on the IPv6 ports.
OUTPUT FROM SWITCH:
switch#sh ip sock
Proto Remote Port Local Port In Out Stat TTY OutputIF
17 --listen-- 192.168.1.1 123 0 0 1001 0
17(v6) --listen-- --any-- 123 0 0 20001 0
17 --listen-- 192.168.1.1 1975 0 0 11 0
17 0.0.0.0 0 192.168.1.1 2228 0 0 211 0
17 0.0.0.0 0 192.168.1.1 67 0 0 2211 0
17 192.168.1.2 63706 192.168.1.1 161 0 0 1001 0
17 --listen-- 192.168.1.1 162 0 0 1011 0
17 --listen-- 192.168.1.1 52919 0 0 1011 0
17(v6) --listen-- --any-- 161 0 0 20001 0
17(v6) --listen-- --any-- 162 0 0 20011 0
17(v6) --listen-- --any-- 54464 0 0 20001 0
17 192.168.1.2 514 192.168.1.1 61483 0 0 400201 0
switch#
As far as I know, this IOS code DOES NOT support IPv6.
Code: c3560-ipbasek9-mz.122-58.SE2.bin
Hardware: WS-C3560G-24PS-S
switch#sh ipv6 route
% Specified IPv6 routing table does not exist
switch#sh ipv6 protocols
switch#
Does anyone have any idea how to shut down these listening ports?
I also have a few production switches listening on UDP/10000 and I cannot determine why this port is listening.
OUTPUT FROM SWITCH:
switch#sh ip sock
17 --listen-- 192.168.1.1 10000 0 0 11 0
17 192.168.1.2 162 192.168.1.1 60310 0 0 0 0
17 --listen-- 192.168.1.1 58064 0 0 1011 0
17 --listen-- --any-- 161 0 0 20001 0
17 --listen-- --any-- 162 0 0 20011 0
17 --listen-- --any-- 60653 0 0 20001 0
17 --listen-- 192.168.1.1 123 0 0 1 0
17 192.168.1.2 514 192.168.1.1 61686 0 0 400201 0
switch#
Code: c3750-ipbasek9-mz.122-55.SE6.bin
Hardware: WS-C3750G-12S-S
I've seen where UDP/10000 is Network Data Management Protocol and is related to Storage networks, but I've also seen where UDP/10000 is the default port for IPSEC data.
I don't believe UDP/10000 is related to either NDMP or IPSEC data, though I could be very wrong.
Any help is very appreciated.
09-28-2012 11:05 AM
Can anyone confirm if Cisco Stack Discovery Protocol uses, by default, UDP/10,000? I believe SDP is the service behind this port, though I've not come across any documentation that covers this aspect of SDP.
03-25-2013 02:12 AM
Hi Khagler24,
Did you ever find an answer? I've got the same issue on an edge 3560-X switch
Rob
03-25-2013 03:11 AM
Sorry and by the same I mean the 3560-X edge switch is listening on UDP/10000 and I'd like to close this port down.
Rob
03-25-2013 07:06 AM
Hi Rob,
Unfortunately no, I have not come across an answer for UDP/10000. I had suspected that it was Cisco's Stack Discovery Protocol until you mentioned having this same issue on a 3560x.
Guess I'll open a TAC case to find out what it is. I'll post here if/when I here something back from Cisco.
Ken
02-02-2016 08:12 PM
Hi Ken,
What was the resolution to UDP 10000?
'Ayo
