08-11-2010 01:28 PM - edited 03-06-2019 12:26 PM
Hello Expert,
I am tring to apply a service policy to a router that is on the frame-relay platform.
The serial interface use sub interface .
When I attempt to apply the service policy the following error message occurs
The qos policy configured with queuing parameters. A qos policy with queuing configuration is not allow on sub interface.
Can anyone assist with a solution.
Jomo
Solved! Go to Solution.
08-17-2010 12:01 PM
Hello Jomo,
To remove the service policy from a Frame Relay (sub)interface, remove the added command frame-relay class. That should do the trick. In order to completely remove any queueing configuration, you should also remove the frame-relay traffic-shaping command from the main physical interface as well.
Best regards,
Peter
08-15-2010 04:34 AM
Can you please post here the configuration of your class maps, policy map and the configuration of the Frame Relay subinterface?
Best regards,
Peter
08-16-2010 07:11 AM
08-16-2010 12:45 PM
Hello Jomo,
Sorry for replying lately. I suggest reading this document:
http://www.cisco.com/en/US/partner/tech/tk543/tk545/technologies_tech_note09186a008009489a.shtml
According to that document, it is necessary to activate the support for the Frame Relay Traffic Shaping. We won't be using the actual shaping but the support for using CBWFQ falls under the FRTS functionality. Then, we can encapsulate the existing policy-map into a map-class construct and use that on the subinterface. Thus, your configuration can be modified as follows:
map-class frame-relay FR_QoS
service-policy output Qos_Internet
interface Serial0/0/0
interface Serial0/0/0.1
frame-relay interface-dlci 16 IETF
class FR_QoS
Give it a try and please let us know if it worked for you. Thanks!
Best regards,
Peter
08-17-2010 05:28 AM
hello Peter,
I am having some problems do the last part of configuration (see below)
class FR_QoS
Note the first two configuration was done okay
Jomo
08-17-2010 05:38 AM
Hello Jomo,
What problems exactly have you ecountered? So far, you have only indicated that something went wrong. Can you describe it in more detail? If the router produced an error message, please post it here as well.
Best regards,
Peter
08-17-2010 07:38 AM
Hello Peter,
I am getting the same error as the first post
This is the config after I did the ajustment on the router
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation frame-relay
ip route-cache flow
no fair-queue
frame-relay lmi-type ansi
interface Serial0/0/0.1 point-to-point
description Linden Wan Interface
ip address xx.x.x.7 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip ospf mtu-ignore
frame-relay class FR_Qos------------------------------------------------------------ unsure about the line
08-17-2010 07:47 AM
Jomo,
That frame-relay class command is okay, you may leave your configuration as it is now and you should now verify whether the QoS policy really works as expected.
Note that you have used a different capitalization - your output contains the string FR_Qos instead of FR_QoS while the name of the map-class was indeed FR_QoS. These names are generally case-sensitive. Can you verify that and correct it?
What worries me, however, is that the command was not accepted under the frame-relay interface-dlci mode. I have tested the syntactical correctness on 2691 IOS 12.4(15)T13 and it was accepted just fine. What is your router and your IOS version? Also, what kind of serial interface are you using?
Best regards,
Peter
08-17-2010 09:16 AM
Hello Peter,
>>> Note that you have used a different capitalization - your output contains the string FR_Qos instead of FR_QoS while the name of the map- class was indeed FR_QoS. These names are generally case-sensitive. Can you verify that and correct it?
I nullify the incorrect string and replace same with the correct (FR_QoS ).
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no fair-queue
no ip redirects
no ip unreachables
no ip proxy-arp
ip ospf mtu-ignore
frame-relay class FR_QoS
This is the show version output of the router: show version
Cisco IOS Software, 2800 Software (C2800NM-ADVSECURITYK9-M), Version 12.4(3i), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 28-Nov-07 21:10 by stshen
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
router07 uptime is 4 weeks, 2 days, 16 hours, 39 minutes
System image file is "flash:c2800nm-advsecurityk9-mz.124-3i.bin"
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FTX1219A0TE
2 FastEthernet interfaces
1 Serial(sync/async) interface
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
08-17-2010 10:34 AM
Hello Jomo,
I will test this IOS on our 2811 in the lab. Nevertheless, please note that your IOS is very old and may contain numerous limitations and bugs.
The current version of your feature set is 12.4(25)c, image name c2800nm-advsecurityk9-mz.124-25c.bin. Alternatively, you could also consider using the 12.4T version which is one generation ahead of 12.4. The latest IOS version in the T train is the 12.4T(24)T3, image name c2800nm-advsecurityk9-mz.124-24.T3.bin
Both images should be appropriate for your hardware configuration.
Best regards,
Peter
08-17-2010 10:40 AM
Hello Peter,
I tried the Qos I think it is working as per result (attachment).
I was tring to use cisco SDM to attach the service policy to subinterface and the error keep occuring
I am think that this kind of configuration may beyond SDM.
When i issue the sh policy-map int I am seeing all class-maps and the relevent queues and traffic flowing thru' the respect queues
which will suggest that all is working.
I attach the results for your you to vet.
08-17-2010 10:58 AM
Hello Peter,
Quick question, if I need remove the service policy from the serial interface how can I do so.
Unlike the Lan interface where the service policy is visible I am unable to distinguish the service-policy on the serial side.
interface FastEthernet0/0
description Linden Lan Interface$ETH-LAN$
ip address xx.xx.xx.xx 255.255.254.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no mop enabled
service-policy input Qos_Internal
08-17-2010 12:01 PM
Hello Jomo,
Best regards,
Peter
08-17-2010 02:02 PM
Hello peter,
Thank you for all the assistance , It was learning expirence for me.
And do keep up the good work
Bye
Jomo
08-17-2010 02:27 PM
Hi Jomo,
You are heartily welcome. If I have the time I'll try to lab up why the class command was not accepted under your DLCI. I still owe you that one
Best regards,
Peter
