unable to boot to flash
Hi. I am currently using a 2600 series router and after installing a module, the router wouldn't boot the flash and just loops back to rommon. When i remove the said module, the router just boots fine into flash. The module is older than the router and i am thinking that the 2600 should be somewhat backward compatible. Please advise.
Thank you.
Re: unable to boot to flash
What WIC and what rotuer are you trying to use it with (IOS version would help as well)
I'm not sure what a router does if you try and use a card when your IOS doesn't have that feature set.
Bronze
Normally the router just logs an "unknown module" message and loads anyway.
Just because a module is "older" than the router platform doesn't mean it will be supported. There are quite a few X6XX modules that aren't supported in the ISRs, for example.
105
