10-29-2010 08:47 AM - edited 03-06-2019 01:47 PM
Hello all,
I have an ASA 5505 firewall connected by a trunk port to a Catalyst 2960. Vlans have been configured and assigned to interfaces on the firewall, and trunk ports configured on both the firewall and the switch. I believe it's configured correctly, because the switch sees the vlans I configured from the firewall.
I also have two windows computers, each connected to switchports confgured for two of the vlans. I can ping the gateway interface (the IP assigned to the vlan at the firewall) successfully from either host. These hosts are located on the soa net, as 192.168.150.100 on switchport 1 and it-dev net, as 192.168.200.100 on switchport 15. Both host's firewalls are turned off.
Thinking I'd configured everything correctly, I attempted to send pings from one host to another, expecting to see deny messages in the live log. Strangely, one of the hosts gets deny messages, and the other gets no deny and the connection shows as opened, but niether host received a reply. Same-security inter and infra-interface is enabled. Even when I create global ICMP rules on the firewall or create ICMP ACL's assigned to the destination interface, this behavior persists.
I also tried telnetting to port 445 from each host to the other, and the host that had it's ping connection opened was able to connect, and the other simply got deny messages.
With same-security inter-interface disabled, either host attempting to telnet to the other generates an "Inbound TCP connection denied..." message in the live log.
The questions I have are:
1. Is enabling same-security inter-interface supposed to be a blanket allow for inter-vlan communication when trunked like this is?
2. Why would one interface, when both interfaces are vlans assigned to the same physical interface and configured the same, be allowed to create connections on the firewall and another not?
3. Why when can I not get a reply back for the connections that are opened?
3. Why would ICMP rules still not allow the traffic through?
I've included the configs for the firewall and the switch. I would really appreciate any help, since I've been banging away at this for days and can't figure out what's wrong with this setup.
ASA Version 8.2(3)
hostname officefw1
enable password XXXX encrypted
passwd XXXX encrypted
names
dns-guard
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
switchport access vlan 50
interface Ethernet0/2
switchport trunk allowed vlan 100,125,150,200
switchport trunk native vlan 999
switchport mode trunk
interface Ethernet0/3
switchport access vlan 250
interface Ethernet0/4
switchport access vlan 251
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
shutdown
nameif inside
security-level 100
no ip address
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Vlan50
nameif dmz
security-level 10
ip address 192.158.50.1 255.255.255.0
interface Vlan100
nameif infrastructure
security-level 100
ip address 192.168.100.1 255.255.255.0
interface Vlan125
nameif voip
security-level 100
ip address 192.168.125.1 255.255.255.0
interface Vlan150
nameif soa
security-level 100
ip address 192.168.150.1 255.255.255.0
interface Vlan200
nameif it-dev
security-level 100
ip address 192.168.200.1 255.255.255.0
interface Vlan250
nameif systems
security-level 100
ip address 192.168.250.1 255.255.255.0
interface Vlan251
nameif management
security-level 100
ip address 192.168.251.1 255.255.255.0
interface Vlan999
no nameif
no security-level
no ip address
boot system disk0:/asa823-k8.bin
ftp mode passive
dns domain-lookup management
dns domain-lookup systems
dns domain-lookup infrastructure
dns domain-lookup voip
dns domain-lookup soa
dns domain-lookup it-dev
dns server-group DefaultDNS
name-server 68.105.28.12
name-server 68.105.29.11
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group service test445 tcp
port-object eq 445
access-list it-dev_access_in extended permit icmp any any inactive
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu management 1500
mtu systems 1500
mtu dmz 1500
mtu infrastructure 1500
mtu voip 1500
mtu soa 1500
mtu it-dev 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-634-53.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
access-group it-dev_access_in in interface it-dev
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.251.0 255.255.255.0 management
http 192.168.250.0 255.255.255.0 systems
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet 192.168.250.0 255.255.255.0 systems
telnet timeout 5
ssh 192.168.250.0 255.255.255.0 systems
ssh timeout 5
console timeout 0
management-access management
dhcpd auto_config outside
dhcpd address 192.168.125.10-192.168.125.30 voip
dhcpd dns 68.15.28.11 68.105.29.12 interface voip
dhcpd enable voip
dhcpd address 192.168.150.10-192.168.150.30 soa
dhcpd dns 68.105.28.12 68.105.29.11 interface soa
dhcpd enable soa
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server 198.123.30.132 source outside prefer
webvpn
anyconnect-essentials
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
no active
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
version 12.2
service config
no service pad
service password-encryption
hostname officesw1
boot-start-marker
boot-end-marker
enable secret 5 XXXX
no aaa new-model
switch 1 provision ws-c2960s-24ts-l
authentication mac-move permit
ip subnet-zero
crypto pki trustpoint HTTPS_SS_CERT_KEYPAIR
enrollment selfsigned
serial-number
revocation-check none
rsakeypair HTTPS_SS_CERT_KEYPAIR
crypto pki certificate chain HTTPS_SS_CERT_KEYPAIR
certificate self-signed 01
<snipped for space>
quit
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
interface FastEthernet0
ip address 192.168.251.10 255.255.255.0
interface GigabitEthernet1/0/1
switchport access vlan 150
spanning-tree portfast
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
switchport access vlan 200
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface Vlan1
no ip address
shutdown
interface Vlan150
no ip address
interface Vlan200
no ip address
no ip http server
ip http secure-server
ip sla enable reaction-alerts
line con 0
line vty 0 4
password 7 XXXX
login
line vty 5 15
password 7 XXXX
login
end
Solved! Go to Solution.
10-31-2010 09:59 AM
Collin,
After more experimentation this morning, I realized I was adding my ACL's to the wrong interface. I did enable same-security inter-interface, and had my ACL's added to the destination interface, which still allowed the traffic. After I added the ACL to the source interface, everything was filtered as expected.
Thanks for your help...
Dan
