Unable to configure vtp mode transparent on Cisco 3548
I'm unable to configure "vtp mode transparent" on a Cisco 3548-XL switch.  It's using IOS c3500XL-c3h2s-mz.120-5.WC3b.bin.  The only options under vtp is "file".
switch(config)# vtp ?
file
Please let me know if I have to upgrade the IOS or removing the vlan.dat file.  This switch was not properly reset to manufacturer's default.  I was given time to reset.
-Manny
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Unable to configure vtp mode transparent on Cisco 3548
It won't.  2900XL/3500XL does not support extended VLAN.
Extended VLANs support starts with the 2940/2950/2955 using version 12.1(22)EA5 and later.
Hall of Fame Super Bronze
Very old IOS.
You need to get into 'vlan database' in order to change the VTP mode.
For instance:
switch#vlan data
switch#(vlan)vtp ?
Edison
I need the extended VLAN range, I only see 1-1005, is this a hardware limitation?
-Manny
Yes you can.  You have to get into the VLAN database (old-fashion way):
Switch#vlan database
Switch(vlan)#vtp transparent
exit
Hope this helps.  Please don't forget to rate useful posts.  Thanks.
It doesn't give me VLAN's 1006 to 4094, the range I need.
-Manny
Thanks for the ratings.
3282
