07-19-2010 11:00 AM - edited 03-06-2019 12:05 PM
Need help to investigate the issue, we have a 2900 cisco cat switch and all ports are configured in vlan 3188 and this siwtch is uplink to 3750 switch which is running in transparent mode. Below is the configuration of both switches, please let me know further to investigate this problem. Attached is the config for 3750 switch.
2900#sh runn
Building configuration...
Current configuration : 12305 bytes
version 12.2
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname hqcns1-602
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone PST -8
clock summer-time PDT recurring
system mtu routing 1500
vtp mode off
authentication mac-move permit
ip subnet-zero
errdisable recovery cause bpduguard
errdisable recovery interval 400
spanning-tree mode rapid-pvst
spanning-tree portfast bpduguard default
spanning-tree etherchannel guard misconfig
ip ssh logging events
ip ssh version 2
interface Port-channel1
switchport mode trunk
interface Port-channel2
interface FastEthernet0/1
switchport access vlan 3190
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface FastEthernet0/25
interface FastEthernet0/26
interface FastEthernet0/27
interface FastEthernet0/28
interface FastEthernet0/29
interface FastEthernet0/30
interface FastEthernet0/31
interface FastEthernet0/32
interface FastEthernet0/33
interface FastEthernet0/34
interface FastEthernet0/35
interface FastEthernet0/36
interface FastEthernet0/37
interface FastEthernet0/38
interface FastEthernet0/39
interface FastEthernet0/40
interface FastEthernet0/41
interface FastEthernet0/42
interface FastEthernet0/43
interface FastEthernet0/44
interface FastEthernet0/45
interface FastEthernet0/46
interface FastEthernet0/47
channel-group 2 mode active
interface FastEthernet0/48
interface GigabitEthernet0/1
channel-group 1 mode active
interface GigabitEthernet0/2
description ### UPLINK TO 3750 - Gi3/0/48 ###
switchport access vlan 3188
spanning-tree portfast disable
Solved! Go to Solution.
07-19-2010 11:19 AM
You need to manually configure an IP address on the 2900 switch.
You need to console into this switch and type the following:
interface Vlan3188
ip address 10.4.188.x 255.255.254.0
ip default gateway 10.4.188.1
Replace the 'x' with a non-conflict number in your network.
Edison
07-19-2010 11:19 AM
interface Vlan3188
Edison
07-19-2010 04:38 PM
Thanks Edison for your response.
The issue got resolved. The issue was with DHCP server. The subnet 10.4.188.0/23 wass not added.
3750 switch is acting like VTP transparent mode and its connected to 3/0/48 towards 0/2 on 2900 switch. I figured it out by connecting two laptops by assigning IP addresses manually on these two different switches. I am able to connected but it was not dynamically alloting the IP addresses from the port.
Well the issue got resolved now.
Hope we work on another issue.
