Unable to perform VLAN Routing
sagarshaha
We recently purchased Cisco 3560X Layer3 Switch. We need to perform simple Inter VLAN routing.  We have configured VLAN1 (name-server_vlan) and VLAN2 (name- user_vlan). We have also assigned the Ports and IP address to both the VLANs. After assiging this if we plug Laptop A into VLAN1 then it doesnt communicates with Laptop B (btw, Laptop A is able to Ping VLAN2 Gateway ) in VLAN2 but on the other hand Laptop B is able to communicate with Laptop A and ping everything i.e. Gateway of VLAN1.
Rquest you to please help in where I am going wrong.
Thanks in advance !
Cheers,
Sagar
17 Replies 17
Peter Paluch
Hi Sagar,
If laptop B can ping laptop A then the routing is working fine. In that case, I suggest to have a close look at the firewall settings on both laptops. Firewalls on Windows are notoriously known for causing similar incidents. Ideally, deactivate the firewall on both laptops for the time being and see if it solves the issue.
Best regards,
Peter
Hi Peter,
Thanks for your reply !!
Firewall on both the laptops are disabled !!
Also, from Switch we are unable to ping Laptop A
Sagar
lgijssel
Level 9
Level 9
Your switch is probably OK.
You have verified that the global command ip routing is in the config?
At least ip forwarding seems to work but the problem description is slightly confusing.
From your explanation, the following are likely causes:
-Incorrect subnet mask on client A or B
-Incorrect or missing default gateway on A or B
regards,
Leo
Hi Leo,
Yes, IP routing is enabled and checked by 'show running-config' command.
Also, we have given common subnet mask on both laptops which are same as VLAN subnet masks.
Also, given correct gateway as given for VLANs
Appreciate your help !!
Sagar
Any access lists configured on the switch perhaps?
Nopes....just starting configuring Inter VLANs
Well, in that case you are definitely overlooking something basic.
How much can there be wrong with this config
Looks like all the options have been mentioned:
-Firewall on clients
-Wrong subnet masks
-Def GW missing or incorrect
Without any detailed information regarding the config, this is merely guessing and I'm not quite good at that.
Basic steps to troubleshoot:
Verify each PC can ping its own gateway
Then try gateway of the other side >> If this works, the cisco part is OK.
Looks like this is your issue which must hence be something with one of the clients or perhaps both.
regards,
Leo
Hi Leo,
I am also not sure where the the problem and we are trying to dig this out from last 8-9 hrs. We have tried changing the clients with different laptops, etc but still no luck
I have attached a network structurediagram which we are planning to build, so that you will get a fair idea about the same. Also, let me know if you want me to forward you the config details of switch.
sagar
Hi Sagar,
A very quick one now that I see which addresses you are using:
conf t
ip subnet zero
end
This should be on by default but you never know.
From your initial description it is not really possible to understand what exactly is the problem.
This is due to some poor english (sorry but thats how it is). Can you please repeat what is working and what not?
Preferrably while using the troubleshooting steps I suggested earlier.
You may paste in the ping results from the pc's in the scheme above, than everyone will understand what you mean.
Leo
Hi Leo,
PFA the ping reports from the PCs and also the running config from the switch
So, currently we have re-created 2 different VLANs than i shown you in the diagram, and still we are facing same issue.
Current Scenario -
VLAN 1 - 20.1.2.1/255.255.255.0
VLAN 2 - 20.1.3.1/255.255.255.0
Issue - LAPTOP A from VLAN1 is unable to communicate with LAPTOP B but LAPTOP B from VLAN 2 is able to
communicate with LAPTOP A
Above snapshot from LAPTOP A
Above Snapshot from LAPTOP B
Config -
KOMLI_L3#sh running-config
Building configuration...
Current configuration : 4076 bytes
version 12.2
no service pad
hostname KOMLI_L3
boot-start-marker
boot-end-marker
enable secret 5 $1$ux3J$ms2dlWauH1hGlfc0hcd5C0
enable password XXXXXXXXXXXX
no aaa new-model
system mtu routing 1500
ip routing
crypto pki trustpoint TP-self-signed-59983872
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-59983872
revocation-check none
rsakeypair TP-self-signed-59983872
crypto pki certificate chain TP-self-signed-59983872
certificate self-signed 01
  3082023D 308201A6 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  2F312D30 2B060355 04031324 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 35393938 33383732 301E170D 39333033 30313030 30313236
  5A170D32 30303130 31303030 3030305A 302F312D 302B0603 55040313 24494F53
  2D53656C 662D5369 676E6564 2D436572 74696669 63617465 2D353939 38333837
  3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281 8100C490
  754E131F E400D3C0 B7B2C0FE BDAABE78 A60AB694 1A3C8FAA 9C43E2CE 137F0AE9
  457FC01D CF847B41 6B802F34 ADE923AB 0FE02560 B8E63AFF 217871EC EC0A71D4
  2A1F7F3C 95C2C59B A28A716E 3A80CA02 82E87AAF 0B266877 3DEA897C A5EA7643
  5A15B9B3 0BD72FC4 3B063273 959FE954 9B25EB0B 0BBCFCFC F26C1972 F1690203
  010001A3 69306730 0F060355 1D130101 FF040530 030101FF 30140603 551D1104
  0D300B82 094B4F4D 4C495F4C 332E301F 0603551D 23041830 168014FD 9D0BBB7D
  567D0062 09C94583 A38F10B7 1A6C0F30 1D060355 1D0E0416 0414FD9D 0BBB7D56
  7D006209 C94583A3 8F10B71A 6C0F300D 06092A86 4886F70D 01010405 00038181
  002A60BB 9CBF7C95 1D44F3C3 9EE27E9B A74E7905 7B472973 0E35D868 A9769196
  983B7B52 8C96A917 26DAB0CD 9E9552D8 831B9A29 F522C184 1B6912EC E6335FDD
  C0823306 42892FD3 0C54AB68 A247C9B8 3D06BE36 75D7419C A0488AE9 3FD94749
  19BB63EE 632C357D 5DE87411 B4111C5D 9B5FD1D7 D4A34B2C FE3ADB88 0D6679A5 E0
  quit
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
no ip route-cache cef
no ip route-cache
no ip mroute-cache
shutdown
interface GigabitEthernet0/1
no switchport
ip address 200.1.1.1 255.255.255.0
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
switchport access vlan 10
interface GigabitEthernet0/5
interface GigabitEthernet0/6
switchport access vlan 20
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
switchport mode access
interface GigabitEthernet0/12
no switchport
ip address 203.212.24.28 255.255.255.248
interface GigabitEthernet0/13
switchport access vlan 3
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface GigabitEthernet1/3
interface GigabitEthernet1/4
interface TenGigabitEthernet1/1
interface TenGigabitEthernet1/2
interface Vlan1
ip address 10.10.10.1 255.0.0.0
interface Vlan2
ip address 20.1.2.1 255.255.255.0
interface Vlan3
ip address 20.1.3.1 255.255.255.0
interface Vlan10
ip address 192.168.0.240 255.255.248.0
interface Vlan20
ip address 172.40.16.1 255.255.248.0
router rip
network 172.40.0.0
network 192.168.0.0
ip classless
ip route 0.0.0.0 0.0.0.0 200.1.1.2
ip route 0.0.0.0 0.0.0.0 203.212.24.25
ip route 172.40.16.0 255.255.248.0 192.168.0.0
ip route 192.168.0.0 255.255.248.0 172.40.16.0
ip http server
ip http secure-server
ip sla enable reaction-alerts
line con 0
line vty 0 4
password xxxxxxxxx
login
line vty 5 15
password XXXXXXXXXX
login
end
IP Route -
KOMLI_L3#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 203.212.24.25 to network 0.0.0.0
     20.0.0.0/24 is subnetted, 2 subnets
C       20.1.3.0 is directly connected, Vlan3
C       20.1.2.0 is directly connected, Vlan2
C    10.0.0.0/8 is directly connected, Vlan1
     203.212.24.0/29 is subnetted, 1 subnets
C       203.212.24.24 is directly connected, GigabitEthernet0/12
S*   0.0.0.0/0 [1/0] via 203.212.24.25
KOMLI_L3#sh ip route summary
IP routing table name is Default-IP-Routing-Table(0)
IP routing table maximum-paths is 32
Route Source    Networks    Subnets     Overhead    Memory (bytes)
connected       1           3           256         608
static          1           0           64          152
rip             0           0           0           0
internal        2                                   2344
Total           4           3           320         3104
KOMLI_L3#sh vlan
VLAN Name                             Status    Ports
1    default                          active    Gi0/2, Gi0/3, Gi0/5, Gi0/7
                                                Gi0/8, Gi0/9, Gi0/10, Gi0/14
                                                Gi0/15, Gi0/16, Gi0/17, Gi0/18
                                                Gi0/19, Gi0/20, Gi0/21, Gi0/22
                                                Gi0/23, Gi0/24
2    v1                               active    Gi0/11
3    v2                               active    Gi0/13
10   SERVER_192                       active    Gi0/4
20   USERS_172                        active    Gi0/6
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
2    enet  100002     1500  -      -      -        -    -        0      0
3    enet  100003     1500  -      -      -        -    -        0      0
10   enet  100010     1500  -      -      -        -    -        0      0
20   enet  100020     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 tr    101003     1500  -      -      -        -    -        0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trnet 101005     1500  -      -      -        ibm  -        0      0
Remote SPAN VLANs
Primary Secondary Type              Ports
KOMLI_L3#sh ip int bri
Interface              IP-Address      OK? Method Status                Protocol
Vlan1                  10.10.10.1      YES NVRAM  up                    up
Vlan2                  20.1.2.1        YES manual up                    up
Vlan3                  20.1.3.1        YES manual up                    up
Vlan10                 192.168.0.240   YES NVRAM  up                    down
Vlan20                 172.40.16.1     YES NVRAM  up                    down
FastEthernet0          unassigned      YES NVRAM  administratively down down
GigabitEthernet0/1     200.1.1.1       YES NVRAM  down                  down
GigabitEthernet0/2     unassigned      YES unset  down                  down
GigabitEthernet0/3     unassigned      YES unset  down                  down
GigabitEthernet0/4     unassigned      YES unset  down                  down
GigabitEthernet0/5     unassigned      YES unset  down                  down
GigabitEthernet0/6     unassigned      YES unset  down                  down
GigabitEthernet0/7     unassigned      YES unset  down                  down
GigabitEthernet0/8     unassigned      YES unset  down                  down
GigabitEthernet0/9     unassigned      YES unset  down                  down
GigabitEthernet0/10    unassigned      YES unset  down                  down
GigabitEthernet0/11    unassigned      YES unset  up                    up
GigabitEthernet0/12    203.212.24.28   YES manual up                    up
GigabitEthernet0/13    unassigned      YES unset  up                    up
GigabitEthernet0/14    unassigned      YES unset  down                  down
GigabitEthernet0/15    unassigned      YES unset  down                  down
GigabitEthernet0/16    unassigned      YES unset  down                  down
GigabitEthernet0/17    unassigned      YES unset  down                  down
GigabitEthernet0/18    unassigned      YES unset  down                  down
GigabitEthernet0/19    unassigned      YES unset  down                  down
GigabitEthernet0/20    unassigned      YES unset  down                  down
GigabitEthernet0/21    unassigned      YES unset  up                    up
GigabitEthernet0/22    unassigned      YES unset  down                  down
GigabitEthernet0/23    unassigned      YES unset  down                  down
GigabitEthernet0/24    unassigned      YES unset  down                  down
GigabitEthernet1/1     unassigned      YES unset  down                  down
GigabitEthernet1/2     unassigned      YES unset  down                  down
GigabitEthernet1/3     unassigned      YES unset  down                  down
GigabitEthernet1/4     unassigned      YES unset  down                  down
TenGigabitEthernet1/1  unassigned      YES unset  down                  down
TenGigabitEthernet1/2  unassigned      YES unset  down                  down
Thanks for your help and patience !!
Windows firewall enabled on Laptop B ?
Dan
Windows Firewall 'Turned Off' oon both the laptops
You should try ruling the switch out and put both problem laptops in the same vlan. If they start to work, then something is going on with intervlan routing. If they still don't work and it follows the laptop, then something is wrong with the laptop. If it all works in vlan 2, move both boxes to vlan 3 and see if the problem occurs. If the problem occurs between both, then you could be having an issue with that vlan, etc.
HTH,
John
HTH, John *** Please rate all useful posts ***
Thanks it worked !!
Firewall issue, it was actually not turned off on LAPTOP B.
Maybe I am asking more now I need a further help on adding my Firewall to switch and configure the same. Can you please help me in same?
I dont want to disturb the current setup on firewall and add new scope of User Vlan.
Current Firewall Scenario -
DHCP Server Scope - 192.168.0.1 to 192.168.1.254 /255.255.254.0
Cheers,
Sagar
