Unable to Ping ISP Default Gateway from 2911/K9
shimabuku
I am unable to ping my ISP default gateway from the 2911/K9. I have verifed the ISP connection by directly connecting the cable to my laptop with static ip addresses. Here is the running config and show version. Any help is greatly appreciated. Thanks!
Current configuration : 1468 bytes
! Last configuration change at 19:14:59 UTC Mon Sep 9 2013
version 15.0
hostname Router
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/0
no logging console
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip name-server 24.xxx.xxx.xxx
ip name-server 209.xxx.xxx.xxx
ip name-server 8.8.8.8
voice-card 0
license udi pid CISCO2911/K9 sn FTX1453AHDA
license accept end user agreement
license boot module c2900 technology-package securityk9
license boot module c2900 technology-package uck9
license boot module c2900 technology-package datak9
vtp domain cisco
vtp mode transparent
vtp version 2
redundancy
interface Loopback0
ip address 10.0.99.1 255.255.255.0
interface GigabitEthernet0/0
ip address xxx.xxx.xxx.114 255.255.255.252
duplex auto
speed auto
no cdp enable
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.113
control-plane
gatekeeper
shutdown
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
Router# show ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.0(1)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 28-Oct-10 18:32 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M9, RELEASE SOFTWARE (fc1)
Router uptime is 1 hour, 18 minutes
System image file is "flash0:c2900-universalk9-mz.SPA.150-1.M4.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2911/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FTX1453AHDA
3 Gigabit Ethernet interfaces
2 Channelized (E1 or T1)/PRI ports
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2911/K9          FTX1453AHDA
Technology Package License Information for Module:'c2900'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security      securityk9    Evaluation    securityk9
uc            uck9          Evaluation    uck9
data          datak9        Evaluation    datak9
10 Replies 10
shimabuku
and show ip route
Gateway of last resort is xxx.xxx.xxx.113 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 24.43.239.113
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        10.0.99.0/24 is directly connected, Loopback0
L        10.0.99.1/32 is directly connected, Loopback0
      xxx.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        xxx.xxx.xxx.112/30 is directly connected, GigabitEthernet0/0
L        xxx.xxx.xxx.114/32 is directly connected, GigabitEthernet0/0
Nothing seems to be visibly wrong in your current configuration. So you're saying when you ping 24.43.239.113 directly from the router, you get no reponses (i.e. dots, no exclamation marks)? Strange. When you do show ip arp, do you see the MAC address of the default gateway listed? If not, there must be some elementary issue why the router is not capable of communicating with a device on its own directly connected network. If the MAC address of the default gateway is resolved but the gateway still does not respond, would it be possible that it blocks pings? Would you be able in that case to ping another IP, say, 8.8.8.8, or perhaps telnet to an outside TCP port?
Best regards,
Peter
Router#show ip arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  24.43.239.113          39   0013.f75e.1b9c  ARPA   GigabitEthernet0/0
Internet  24.43.239.114           -   503d.e533.2bd0  ARPA   GigabitEthernet0/0
Router#ping 24.43.239.113
Sending 5, 100-byte ICMP Echos to 24.43.239.113, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Router#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
This is very interesting. Are you saying that if you connect a PC instead of the router, and configure the PC with identical IP settings as the router, the PC is able to ping both the gateway address and any address outside?
If yes, let's try one thing. On the router, try entering the following command in the global configuration mode:
no ip cef
This command will deactivate an accelerated mechanism of packet forwarding called CEF on Cisco routers. While deactivating it is highly discouraged, the CEF has sometimes shown glitches that caused symptoms very similar to yours. So try deactivating the CEF using the command above, and then try pinging the gateway again. After the experiment, reactivate the CEF using the ip cef global configuration command.
Best regards,
Peter
Yes.
I have disabled CEF thru global config mode and still cannot ping the gateway. Maybe there is an issue with this particular IOS image?
I do not believe this is an IOS issue at this point. Such a grave error would be detected soon.
Reactivate the CEF, please, and let's try one more experiment. Try configuring your laptop with the IP address 24.43.239.113/30 and connect it to your router's Gi0/0 port instead of the ISP. Then try pinging the router from the laptop, and the laptop from the router (you may want to temporarily disable the Windows firewall on the laptop that like to skew the results). If this ping works then the router is not faulty, and we have to focus on the ISP connection. If the ping between the router and the laptop does not work from either side, there is something very fishy going on.
Best regards,
Peter
Unable to configure laptop with that particular ip address and mask. I get an error "You entered an invlaid subnet mask. The subnet mask has to be contiguous. Please enter a valid mask."
I have attached a WS-C3550-48-EMI to G0/1 on the router and enabled ip routing on the switch.
ip address 10.0.0.1 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/48
no switchport
ip address 10.0.0.2 255.255.255.252
Unable to ping from switch to router and vice versa. Also disabled/enabled CEF on the router and switch.
Also unable to see it as a cdp neighbor on both sides.
Regarding the configuration of your laptop, you must have made a typo in the netmask you were configuring - this is what it meant by saying "the subnet mask has to be contiguous". I am sure the address of 24.43.239.113 and netmask 255.255.255.252 is a usable combination.
Regarding the inability to ping between your router and the C3550, I am confused. There is either a very elementary error we're doing, or the router is a brick.
Can you at least ping your own IP addresses on the router? Are the interfaces on the router and switch in the up/up state?
Best regards,
Peter
for the router to ISP gateway ping failure(as well as ping to 8.8.8.8),can you get the MAC address of the working laptop NIC with ipconfig/all then go to the router and on the interface connected to the ISP gateway issue this command:
int g0/0
mac-address xxxx.xxxx.xxxx where xxxx.xxxx.xxxx is the MAC you discovered with the ipconfig/all on the working PC.
Alain
