Unable to ping printers
I randomly lose ICMP connection to my printers from my 1720 router. Once I ping the IP from the router the first packet fails and the next four are good. Any ideas?
Re: Unable to ping printers
Hi Tom,
Your first statement is you randomly loose connection but your second statement is only first packet fails and rest all goes fine.
Your second situation is normal because when you ping from your router, your router may not be having an arp entry for which it drops the first packet and when entry is build it all 4 packtes will go fine.
Ankur
Sorry for the confusion. Let me clear that up a little. My workstations lose that are local and remote terminal servers lose connection to printers. Once I ping them from the router they regain connectivity and work fine. Once the printers are back up I am able to ping them from the router and not have any failed pings.
Hi Tom.
Did you already tried to set up a fixed MAC Address entry for the printers on the switch?
regards,
Gold
are all the devices on the same subnet/network?
check your arp table and make static entries if necessary.
The terminal servers are on a different network, but the local PC's are on the same network. How do I make a static entry. I have used the DHCP pool feature, but is there another way?
232
