Webcast-Catalyst9k
Unable to ping some vlan gateways from Nexus Switch
Dear Friends,
I configured 2 Nexus 3048 Switch, from 1 switch(NAGISNEXUS_1) i can able to ping all vlan Gateways,
but at the same time from another Switch(NAGISNEXUS_2) i am unable to Ping any vlan gateways except Default Vlan (vlan1)
hereby provided the both configurations for your Reference.
Please help me out.
NAGISNEXUS_1 ( Not working)
NAGISNEXUS_1# sh ru
!Command: show running-config
!Time: Wed Jan 29 11:45:44 2014
version 5.0(3)U3(2)
no feature telnet
no telnet server enable
cfs eth distribute
feature interface-vlan
feature lacp
feature vpc
feature lldp
username admin password 5 $1$O2w2Kr/1$BScZGI4t1bKcPVf6wIlYX1  role network-admin
ip domain-lookup
switchname NAGISNEXUS_1
ipv6 access-list copp-system-acl-dhcpc6
  10 permit udp any any eq 546
ipv6 access-list copp-system-acl-dhcps6
  10 permit udp any ff02::0001:0002/128 eq 547
  20 permit udp any ff05::0001:0003/128 eq 547
ip access-list copp-system-acl-eigrp
  10 permit eigrp any 224.0.0.10/32
ipv6 access-list copp-system-acl-eigrp6
  10 permit 88 any ff02::000a/128
ip access-list copp-system-acl-icmp
  10 permit icmp any any
ip access-list copp-system-acl-igmp
  10 permit igmp any any
ip access-list copp-system-acl-ntp
  10 permit udp any any eq ntp
  20 permit udp any eq ntp any
ip access-list copp-system-acl-pimreg
  10 permit pim any any
ip access-list copp-system-acl-ping
  10 permit icmp any any echo
  20 permit icmp any any echo-reply
ip access-list copp-system-acl-routingproto1
  10 permit tcp any gt 1024 any eq bgp
  20 permit tcp any eq bgp any gt 1024
  30 permit udp any 224.0.0.0/24 eq rip
  40 permit tcp any gt 1024 any eq 639
  50 permit tcp any eq 639 any gt 1024
  70 permit ospf any any
  80 permit ospf any 224.0.0.5/32
  90 permit ospf any 224.0.0.6/32
ip access-list copp-system-acl-routingproto2
  10 permit udp any 224.0.0.0/24 eq 1985
  20 permit 112 any 224.0.0.0/24
ip access-list copp-system-acl-snmp
  10 permit udp any any eq snmp
  20 permit udp any any eq snmptrap
ip access-list copp-system-acl-ssh
  10 permit tcp any any eq 22
  20 permit tcp any eq 22 any
ip access-list copp-system-acl-stftp
  10 permit udp any any eq tftp
  20 permit udp any any eq 1758
  30 permit udp any eq tftp any
  40 permit udp any eq 1758 any
  50 permit tcp any any eq 115
  60 permit tcp any eq 115 any
ip access-list copp-system-acl-tacacsradius
  10 permit tcp any any eq tacacs
  20 permit tcp any eq tacacs any
  30 permit udp any any eq 1812
  40 permit udp any any eq 1813
  50 permit udp any any eq 1645
  60 permit udp any any eq 1646
  70 permit udp any eq 1812 any
  80 permit udp any eq 1813 any
  90 permit udp any eq 1645 any
  100 permit udp any eq 1646 any
ip access-list copp-system-acl-telnet
  10 permit tcp any any eq telnet
  20 permit tcp any any eq 107
  30 permit tcp any eq telnet any
  40 permit tcp any eq 107 any
ipv6 access-list copp-system-acl-v6routingProto2
  10 permit udp any ff02::0066/128 eq 2029
  20 permit udp any ff02::00fb/128 eq 5353
ipv6 access-list copp-system-acl-v6routingproto1
  10 permit 89 any ff02::0005/128
  20 permit 89 any ff02::0006/128
  30 permit udp any ff02::0009/128 eq 521
ip access-list copp-system-dhcp-relay
  10 permit udp any eq bootps any eq bootps
policy-map type network-qos jumbo
  class type network-qos class-default
    mtu 9000
system qos
  service-policy type network-qos jumbo
class-map type control-plane match-any copp-icmp
  match access-group name copp-system-acl-icmp
class-map type control-plane match-any copp-ntp
  match access-group name copp-system-acl-ntp
class-map type control-plane match-any copp-s-arp
class-map type control-plane match-any copp-s-bfd
class-map type control-plane match-any copp-s-bpdu
class-map type control-plane match-any copp-s-dai
class-map type control-plane match-any copp-s-default
class-map type control-plane match-any copp-s-dhcpreq
  match access-group name copp-system-acl-dhcps6
class-map type control-plane match-any copp-s-dhcpresp
  match access-group name copp-system-acl-dhcpc6
  match access-group name copp-system-dhcp-relay
class-map type control-plane match-any copp-s-eigrp
  match access-group name copp-system-acl-eigrp
  match access-group name copp-system-acl-eigrp6
class-map type control-plane match-any copp-s-glean
class-map type control-plane match-any copp-s-igmp
  match access-group name copp-system-acl-igmp
class-map type control-plane match-any copp-s-ipmcmiss
class-map type control-plane match-any copp-s-l2switched
class-map type control-plane match-any copp-s-l3destmiss
class-map type control-plane match-any copp-s-l3mtufail
class-map type control-plane match-any copp-s-l3slowpath
class-map type control-plane match-any copp-s-pimautorp
class-map type control-plane match-any copp-s-pimreg
  match access-group name copp-system-acl-pimreg
class-map type control-plane match-any copp-s-ping
  match access-group name copp-system-acl-ping
class-map type control-plane match-any copp-s-ptp
class-map type control-plane match-any copp-s-routingProto1
  match access-group name copp-system-acl-routingproto1
  match access-group name copp-system-acl-v6routingproto1
class-map type control-plane match-any copp-s-routingProto2
  match access-group name copp-system-acl-routingproto2
class-map type control-plane match-any copp-s-selfIp
class-map type control-plane match-any copp-s-ttl1
class-map type control-plane match-any copp-s-v6routingProto2
  match access-group name copp-system-acl-v6routingProto2
class-map type control-plane match-any copp-snmp
  match access-group name copp-system-acl-snmp
class-map type control-plane match-any copp-ssh
  match access-group name copp-system-acl-ssh
class-map type control-plane match-any copp-stftp
  match access-group name copp-system-acl-stftp
class-map type control-plane match-any copp-tacacsradius
  match access-group name copp-system-acl-tacacsradius
class-map type control-plane match-any copp-telnet
  match access-group name copp-system-acl-telnet
policy-map type control-plane copp-system-policy
  class copp-s-selfIp
    police pps 500
  class copp-s-default
    police pps 400
  class copp-s-l2switched
    police pps 200
  class copp-s-ping
    police pps 100
  class copp-s-l3destmiss
    police pps 100
  class copp-s-glean
    police pps 500
  class copp-s-l3mtufail
    police pps 100
  class copp-s-ttl1
    police pps 100
  class copp-s-ipmcmiss
    police pps 400
  class copp-s-l3slowpath
    police pps 100
  class copp-s-dhcpreq
    police pps 300
  class copp-s-dhcpresp
    police pps 300
  class copp-s-dai
    police pps 300
  class copp-s-igmp
    police pps 400
  class copp-s-eigrp
    police pps 200
  class copp-s-pimreg
    police pps 200
  class copp-s-pimautorp
    police pps 200
  class copp-s-routingProto2
    police pps 1300
  class copp-s-v6routingProto2
    police pps 1300
  class copp-s-routingProto1
    police pps 1000
  class copp-s-arp
    police pps 200
  class copp-s-ptp
    police pps 1000
  class copp-s-bfd
    police pps 350
  class copp-s-bpdu
    police pps 12000
  class copp-icmp
    police pps 200
  class copp-telnet
    police pps 500
  class copp-ssh
    police pps 500
  class copp-snmp
    police pps 500
  class copp-ntp
    police pps 100
  class copp-tacacsradius
    police pps 400
  class copp-stftp
    police pps 400
control-plane
  service-policy input copp-system-policy
snmp-server user admin network-admin auth md5 0xdf83cce2f64104e0e5946cb883292e9b
priv 0xdf83cce2f64104e0e5946cb883292e9b localizedkey
vrf context management
  ip route 0.0.0.0/0 172.90.0.1
vlan 1
vlan 2
  name NFS-VLAN
vlan 3
  name VMotion-VLAN
vlan 4
  name VM-Traffic-VLAN
vlan 5
  name MGMT-VLAN
spanning-tree port type edge bpduguard default
spanning-tree port type network default
lacp system-priority 1
port-channel load-balance ethernet source-dest-port
vpc domain 1
  role priority 10
  peer-keepalive destination 172.90.0.3 source 172.90.0.2
interface Vlan1
  no shutdown
  ip address 192.168.50.9/24
interface Vlan2
  no shutdown
  description NFS-VLAN
  ip address 192.168.51.2/24
interface Vlan3
  no shutdown
  description VMotion-VLAN
  ip address 192.168.52.2/24
interface Vlan4
  no shutdown
  description VM-Traffic-VLAN
  ip address 192.168.53.2/24
interface Vlan5
  no shutdown
  description MGMT-VLAN
  ip address 172.90.0.2/24
interface port-channel1
  switchport mode trunk
  switchport trunk allowed vlan 1-5
  speed 1000
interface port-channel10
  description vPC peer-link
  vpc peer-link
  spanning-tree port type edge trunk
  speed 1000
  negotiate auto
interface port-channel11
  description vPC to FAS-1
  vpc 11
  switchport trunk allowed vlan 1-2,4
  speed 1000
  negotiate auto
interface port-channel12
  description vPC to FAS-2
  vpc 12
  speed 1000
  negotiate auto
interface Ethernet1/1
  description FAS-1:e0a
  speed 1000
  negotiate auto
  channel-group 11 mode active
interface Ethernet1/2
  description FAS-2:e0a
  speed 1000
  negotiate auto
  channel-group 12 mode active
interface Ethernet1/3
  description FAS-1:e0c
  speed 1000
  negotiate auto
interface Ethernet1/4
  description FAS-2:e0c
  speed 1000
  negotiate auto
interface Ethernet1/5
  negotiate auto
interface Ethernet1/6
  negotiate auto
interface Ethernet1/7
  switchport access vlan 5
  speed 1000
  negotiate auto
interface Ethernet1/8
  negotiate auto
interface Ethernet1/9
  negotiate auto
interface Ethernet1/10
  negotiate auto
interface Ethernet1/11
  negotiate auto
interface Ethernet1/12
  negotiate auto
interface Ethernet1/13
  description Server-1:port1
  speed 1000
  negotiate auto
interface Ethernet1/14
  description Server-1:port2
  speed 1000
  negotiate auto
interface Ethernet1/15
  description Server2-port1
  speed 1000
  negotiate auto
interface Ethernet1/16
  description Server-2:port2
  speed 1000
  negotiate auto
interface Ethernet1/17
  description Server-3:port1
  speed 1000
  negotiate auto
interface Ethernet1/18
  description Server-3:port2
  speed 1000
  negotiate auto
interface Ethernet1/19
  description Server-4:port1
  speed 1000
  negotiate auto
interface Ethernet1/20
  description Server-4:port2
  speed 1000
  negotiate auto
interface Ethernet1/21
  speed 1000
  negotiate auto
interface Ethernet1/22
  negotiate auto
interface Ethernet1/23
  negotiate auto
interface Ethernet1/24
  negotiate auto
interface Ethernet1/25
  description vPC peer-link SwB:1/25
  speed 1000
  negotiate auto
  channel-group 10 mode active
interface Ethernet1/26
  description vPC peer-link SwB:1/26
  speed 1000
  negotiate auto
interface Ethernet1/27
  negotiate auto
interface Ethernet1/28
  negotiate auto
interface Ethernet1/29
  negotiate auto
interface Ethernet1/30
  negotiate auto
interface Ethernet1/31
  negotiate auto
interface Ethernet1/32
  negotiate auto
interface Ethernet1/33
  negotiate auto
interface Ethernet1/34
  negotiate auto
interface Ethernet1/35
  negotiate auto
interface Ethernet1/36
  negotiate auto
interface Ethernet1/37
  description Server-1:mgmt
  speed 1000
  negotiate auto
interface Ethernet1/38
  description Server-3:mgmt
  speed 1000
  negotiate auto
interface Ethernet1/39
  description FAS-1:mgmt
  speed 1000
  negotiate auto
interface Ethernet1/40
  negotiate auto
interface Ethernet1/41
  negotiate auto
interface Ethernet1/42
  negotiate auto
interface Ethernet1/43
  negotiate auto
interface Ethernet1/44
  negotiate auto
interface Ethernet1/45
  negotiate auto
interface Ethernet1/46
  negotiate auto
interface Ethernet1/47
  negotiate auto
interface Ethernet1/48
  negotiate auto
interface Ethernet1/49
  no lldp transmit
  no lldp receive
  speed 1000
  channel-group 1
interface Ethernet1/50
interface Ethernet1/51
interface Ethernet1/52
interface mgmt0
interface loopback1
  shutdown
line console
line vty
boot kickstart bootflash:/n3000-uk9-kickstart.5.0.3.U3.2.bin
boot system bootflash:/n3000-uk9.5.0.3.U3.2.bin
ip route 0.0.0.0/0 192.168.50.11
NAGISNEXUS_2 ( Working)
NAGISNEXUS_2# sh ru
!Time: Wed Jan 29 11:45:53 2014
version 5.0(3)U3(2)
no feature telnet
cfs eth distribute
feature lacp
feature vpc
feature lldp
username admin password 5 $1$7pFsWQps$AR8qNoWg/QYrJsZYA96YT.  role network-admin
ip domain-lookup
switchname NAGISNEXUS_2
    mtu 9000
system qos
  class copp-s-selfIp
    police pps 500
    police pps 400
    police pps 200
  class copp-s-ping
    police pps 100
    police pps 100
  class copp-s-glean
    police pps 500
    police pps 100
  class copp-s-ttl1
    police pps 100
    police pps 400
    police pps 100
    police pps 300
    police pps 300
  class copp-s-dai
    police pps 300
  class copp-s-igmp
    police pps 400
  class copp-s-eigrp
    police pps 200
  class copp-s-pimreg
    police pps 200
    police pps 200
    police pps 1300
    police pps 1300
    police pps 1000
  class copp-s-arp
    police pps 200
  class copp-s-ptp
    police pps 1000
  class copp-s-bfd
    police pps 350
  class copp-s-bpdu
    police pps 12000
  class copp-icmp
    police pps 200
  class copp-telnet
    police pps 500
  class copp-ssh
    police pps 500
  class copp-snmp
    police pps 500
  class copp-ntp
    police pps 100
    police pps 400
  class copp-stftp
    police pps 400
control-plane
snmp-server user admin network-admin auth md5 0xa3efbf4c6f3500828eef3b67da8c67e2
priv 0xa3efbf4c6f3500828eef3b67da8c67e2 localizedkey
vlan 1
vlan 2
  name NFS-VLAN
vlan 3
  name vMotion-VLAN
vlan 4
vlan 5
  name MGMT-VLAN
lacp system-priority 2
vpc domain 1
  role priority 10
  peer-keepalive destination 172.90.0.2 source 172.90.0.3
interface Vlan1
  no shutdown
  ip address 192.168.50.8/24
interface Vlan2
  no shutdown
  ip address 192.168.51.3/24
interface Vlan3
  no shutdown
  ip address 192.168.52.3/24
interface Vlan4
  no shutdown
  ip address 192.168.53.3/24
interface Vlan5
  no shutdown
  ip address 172.90.0.3/24
  speed 1000
  vpc peer-link
  speed 1000
  negotiate auto
  vpc 11
  speed 1000
  negotiate auto
  vpc 12
  speed 1000
  negotiate auto
  description FAS-1:e0b
  speed 1000
  negotiate auto
  description FAS-2:e0b
  speed 1000
  negotiate auto
  description FAS-1:e0d
  speed 1000
  negotiate auto
  description FAS-2:e0d
  speed 1000
  negotiate auto
  negotiate auto
  negotiate auto
  speed 1000
  negotiate auto
  negotiate auto
  negotiate auto
  negotiate auto
  negotiate auto
  negotiate auto
  description Server-1:port3
  speed 1000
  negotiate auto
  description Server-1:port4
  speed 1000
  negotiate auto
  description Server-2:port3
  speed 1000
  negotiate auto
  description Server-2:port4
  speed 1000
  negotiate auto
  description Server-3:port3
  speed 1000
  negotiate auto
  description Server-3:port4
  speed 1000
  negotiate auto
  description Server-4:port3
  speed 1000
  negotiate auto
  description Server-4:port4
  speed 1000
  negotiate auto
  speed 1000
  negotiate auto
  negotiate auto
  negotiate auto
  negotiate auto
  speed 1000
  negotiate auto
  speed 1000
  negotiate auto
  negotiate auto
  negotiate auto
  negotiate auto
  negotiate auto
  negotiate auto
  negotiate auto
  negotiate auto
  negotiate auto
  negotiate auto
  negotiate auto
  description Server-2:mgmt
  speed 1000
  negotiate auto
  description Server-4:mgmt
  speed 1000
  negotiate auto
  description FAS-2:mgmt
  speed 1000
  negotiate auto
  negotiate auto
  negotiate auto
  negotiate auto
  negotiate auto
  negotiate auto
  negotiate auto
  negotiate auto
  negotiate auto
  negotiate auto
  no lldp transmit
  no lldp receive
  speed 1000
  channel-group 1
interface mgmt0
interface loopback1
  shutdown
line console
line vty
Tamizh.K
207
