02-04-2014 10:56 AM - edited 03-07-2019 06:00 PM
Hello Experts
I have 3 servers connected to Cisco Catalyst Switch C2960 and this switch has uplink to one of the access switch and ultimately this access switch connected to our 2 Core Switch
We are running HSRP and core switches has direct link between them.
Today I encountered an issue these server are unreachable from vlans other that its own. I just cleared arp-cache and it started pinging.
Please can you help since this happening repeadetly.
02-04-2014 12:40 PM
To go with Jon Marshall's recent post you can do that by doing the following.
1. Ping the IP Address
2. 'show arp | i IP-Address
3. 'show mac-address table | i IP-Address' *** Command for show mac address table may vary on the switch ***
This will show you the port it was learned from and you can do 'show cdp neighbor' and trace it form switch to switch that way.
02-04-2014 12:53 PM
1.show arp | i IP-Address
Core Switch
Internet 10.1.1.17 16 0014.5ebc.7466 ARPA Vlan2
2. show mac-address table | i IP-Address
no mac address found
3. Core 1
sh mac-address-table address 0014.5ebc.7466
2 0014.5ebc.7466 dynamic Yes 35 Gi1/1 ( connected to access switch)
Access Switch
2 0014.5ebc.7466 DYNAMIC Gi1/0/44 ( connected to 2960 switch)
HSRP Config
Core 1
interface Vlan2 ip address 10.1.1.254 255.255.255.0 ip route-cache flow standby delay minimum 20 reload 25 standby 1 ip 10.1.1.1 standby 1 priority 110 standby 1 preempt
Core 2interface Vlan2 ip address 10.1.1.253 255.255.255.0 ip route-cache flow standby delay minimum 20 reload 25 standby 2 ip 10.1.1.1 standby 2 priority 95 standby 2 preempt
Sh standby
Core 1Vlan2 - Group 2 Local state is Active, priority 110, may preempt Hellotime 3 sec, holdtime 10 sec Next hello sent in 1.143 Virtual IP address is 10.1.1.1 configured Active router is local Standby router is 10.1.1.253 expires in 9.844 Virtual mac address is 0000.0c07.ac02 1 state changes, last state change 8w1d IP redundancy name is "hsrp-Vl2-2" (default)
Core 2
Vlan2 - Group 2 Local state is Standby, priority 95, may preempt Hellotime 3 sec, holdtime 10 sec Next hello sent in 1.931 Virtual IP address is 10.1.1.1 configured Active router is 10.1.1.254, priority 110 expires in 7.440 Standby router is local 43 state changes, last state change 8w1d IP redundancy name is "hsrp-Vl2-2" (default)
02-04-2014 12:42 PM
1. are the non working servers in the same vlan as the working servers ?
No. they are in same vlan
2.how do you know the servers can't ping the VIP, is someone else doing that for you ? If so can they do an "arp -a" on the server and look for the VIP entry ?
Actually this is a medical server, the vendor logged in during the issue and discovered that they cannot ping the default gateway i.e VIP.
3. can you pick one of the non working servers and trace it's mac address from the core switch ie. on each switch up to the 2960 can you look in the mac address tables and make sure the mac for that server is going out of the right port.
Yes they are coming on right port
02-04-2014 12:46 PM
Can you post the HSRP config for this vlan from each router? Also can you post the results from 'show standby' with the specific HSRP number from each router?
02-04-2014 12:52 PM
When you cannot connect to the server ie. before you clear the arp cache on the core switch, is the mac address that is showing against the server IP the correct one or does it change after you clear the arp cache.
Jon
02-04-2014 12:54 PM
It remains the same.
02-04-2014 12:56 PM
One thing to be noted
2 servers showing same mac
0014.5ebc.7466
02-04-2014 12:58 PM
2 IP addresses
10.1.1.15 and 17 show mac address entry in the mac table on core
02-04-2014 12:59 PM
Are these two of the servers not working ?
Jon
02-04-2014 12:59 PM
Okay, well that could well stop communication working ie. one server sends ping to VIP but the return packet is sent to the other server.
So i suspect you need to get that fixed.
Are both the servers showing the same mac address not working ?
Jon
02-04-2014 01:02 PM
I have just communicated with server team and came to some information that
they have 2 servers 10.1.1.14 and 15 they are working as HA. and IP 17 is working like a virtual IP. and its working like active IP.
02-04-2014 01:04 PM
I noticed something on your HSRP configuration.
HSRP Config
Core 1
You have a priority of 110, if there is an issue, it wil go down by a default priority of 10, which will leave it at a priority of 100 which is higher than core2 HSRP config for this vlan.
02-04-2014 01:07 PM
But the whole is not going down, the other servers and clients in the same vlan can ping the VIP.
02-04-2014 01:04 PM
server 10.1.1.14 and 15 not working and 17 virtual on server not working as well.
02-04-2014 01:08 PM
So if you generate a ping from one of those servers what should be the source IP ie. it's real IP or it's VIP ?
When you said you run a continous ping from a client which IP are you pinging ?
Jon
